Results 1 to 11 of 11
    Established Member Two Rings Bumpo411's Avatar
    Jun 09 2015
    Portland, Maine
    Question Power Steering Pump
    I have a 04 3.0 and it seems that I will need to replace my power steering pump but I would like to know if there is a rebuild kit? I'm not opposed to buying new and simply replacing it but if if I have the option to rebuild it, I would.
    Jun 08 2008
    Calgary AB Canada
    Are you sure it's the pump and not the common air leak?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Jun 09 2015
    Portland, Maine
    I know it's my power steering pump, I was just seeing if anyone knew of a rebuild kit?
    May 21 2011
    b5 4.2
    Atlanta, GA
    Jun 09 2015
    Portland, Maine
    Does anyone know where I can find the kit?
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Quote Originally Posted by Bumpo411 View Post
    Did you read the thread that was just linked? It gives you details on where to get the rebuild kit. Also, I know you said that you know it is the pump, but you provided no details about how you know, so how should anyone else know that it is the
    Jun 09 2015
    Portland, Maine
    Quote Originally Posted by imnuts View Post
    The kit says that it's for a 1994-1998 steering pump. They don't seem to have a kit for anything after 2002 and I followed the noise fix and etc. and none of them fixed it. I also had someone who is a respected mechanic tell me it was the pump
    Aug 12 2009
    Dirty Jerz
    Maybe re-read the thread around the link to the rebuild kit?
    Aug 27 2013
    Philly
    Come on now, you know that people don't like looking for their own data.
    Either way, RockAuto has New and Reman pumps between $100-$250. Since this is such a cheap part, I don't even think its worth trying to fix. Not when you factor in all of the time and risk of improper seal installation (causing more leaks/down time). I personally would grab a Reman unit (likely the AC Delco) and then call it a day.
    Jan 09 2012
    MA
    I have a spare that was kind of "iffy" performance. After reading that write up it does not look too complex so if i get bored this winter I may pull it apart just to have a look see.
