Results 1 to 7 of 7
Hybrid View
    Senior Member Two Rings X-ZZ4's Avatar
    Jun 28 2015
    Oregon
    Why does my car run like crap when it's cold?
    I don't mean cold outside, I mean like sitting over night and starting in the morning.
    It's done this ever since I bought it, but I've had bigger issues and ignored this because it runs ok when it warms up. But now I got most everything else fixed (at least for now)....So I'd like to knock this one out now if I can.
    Start it in the morning. Runs like it misses, but there's no codes. If you don't let it warm up for a minute. It feels like it has no vacuum also because the brakes barely work also. Give it 30 seconds, brakes come back, give it a minute, runs fine.
    Is there a "warm up sensor"...lol?
    Help on where I should begin troubleshooting is appreciated.
    2002 Audi A6 2.7T Quattro
    K04's, Solo Motorsports Intake with 85mm MAF, Bosch 550's, Stage 3 Tune, H&R lowering springs, TSW wheels, other misc crap.
    Recently Gone:
    1999 Chev Corvette - Nitrous, 499RWHP
    2004 Pontiac GTO - Nitrous, 528RWHP
    https://www.youtube.com/watch?v=fQ2r5QQ6jaw
    Veteran Member Three Rings G0to60's Avatar
    Oct 25 2011
    90 Corrado, 02 allroad
    Milwaukie, OR
    You could try replacing the coolant temp sensor. I'm not sure if it's exactly the same but some of my older cars would run like crap when cold if this sensor was bad. It's also nice that they are cheap and easy to swap out.
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    On a car that old its conceivable that you may have multiple issues but it sound like at the very least you have a vacuum leak.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by carmudgeon View Post
    ^^ X2 . My 2002 6MT has what looks like a tee fitting in a hose running from the underside of the accordion hose, with one line running to the power brake booster. The tee fitting on mine came apart and caused the same symptoms; the tee is actually called a "suction pump" and is part of this assembly: https://www.ecstuning.com/ES2664091/...FY17fgod4yUIGQ
    I glued mine back together with 5 minute epoxy ... 7 years ago ...
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Jun 28 2015
    Oregon
    Quote Originally Posted by 02 A6 2.7T View Post
    Did your symptoms only occur cold? I would think a vacuum leak would cause other problems as well. Mine runs fine once it warms up a bit.
    Recently Gone:
    Jun 28 2015
    Oregon
    Thanks for the help. I didn't know my car was old. Now this solves everything.
    Recently Gone:
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Whatever is leaking expands when the engine warms, thats why it feels a little better. I would check every visible connection or joint you can. Touch the vacuum lines, bend em back and forth a little. Thought mine were great and then i just touched it them and revealed a crack right by where the line meets the diverter valve for example. Hear any hissing?
