Originally Posted by
jomama229
is this "roadforce" that you speak of the tire balancing machine? if so, any reason why the dws 06 no "roadforce" well?
It's been explained to me that roadforce is different than balancing. When a tire is first mounted on a rim, the roadforce machine is able to read where the high point is on the tire, and from there suggests where to match this up with what it recognizes as the low point on the rim, also called 'indexing'. This helps to mitigate any out of round assemblies (tire and wheel together) for a smoother ride. Tires are rarely perfectly round. A roadforce reading is expressed in terms of lbs of spring rate, and most shops will agree that any match of 24 lbs or under is acceptable. Anything over needs to be re-indexed. Once indexed, balancing fine tunes the assembly at speed. You'll notice assemblies that have been road forced to low tolerances will have far fewer weights placed on the rim because the tire and wheel are so well indexed or mated together.
I can't comment on the new DWS 06, however did find that the original DWS was hard to achieve a good balanced ride. Always seemed a tad out of balance, and I attribute this to the tire being out of round. Could be this gremlin still exists..?
