Results 1 to 11 of 11
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Lightweight Wheels Effect
    Ive been reading on the effect on handling and acceleration that lightweight wheels have due to the impact unsprung weight causes. What is the weight of the OEM "Flower" wheels? Like 29#??? Is shedding 9# on each corner that noticeable in handling and to the "Butt Dyno"?
    Apr 04 2012
    MSP
    Shedding 9lbs per corner of rotational weight would be very noticeable. Even more-so if reducing the wheel diameter while at it.
    OEM wheels weigh close to 50lbs (with tires) if I'm not mistaken.
    Nov 16 2015
    DFW
    Well I am keeping the stock tires (Conti's). Once those wear I will be going with PSS's and that will shed even more weight.
    Oct 14 2012
    Empty...for now...
    SE PA
    Lighter weight wheel + tire assembly, especially 9 lbs less, will be noticeable both in acceleration and in braking. In fact you may even notice better response from your shocks insofar as quick rebound due to the shocks having to push less weight.
    As MrFunk mentioned, a decrease in diameter as well as weight would be an even bigger help. The resistance to roll is inertia, which is a measure of the distribution of the wheel's mass relative to its rotational axis.
    SOLD 2015 Daytona Gray S4
    Jul 10 2012
    buffalo
    lighter wheels and tires make everything better. A 9lb reduction will not go unnoticed
    1995 camaro with taurus SHO engine
    2001 audi a8 gutted because race car
    2009 chevy express 2500 duramax built 4L85E trans and tuned for around 400hp
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    On modern car like ours, the suspension was actually designed for a heavier tire wheel combo, so its not as bad as putting heavy +3 wheels and tires on some early 90's car. That said, there are a lot of tests posted online that show a very minor acceleration improvement in dramatically lowering wheel weight. In my experience, the effect I noticed the most was shock response being better, and the car feeling overall more responsive to inputs. Makes sense, as a heavier tire wheel in motion will not be as responsive to change as a lighter one.
    https://www.google.com/webhp?sourcei...eration+tested
    Jun 11 2011
    Noticeable for me shaving off 8lbs or so per corner. Feels like it's much more responsive with acceleration / braking. Car doesn't feel as heavy essentially. Shocks are tad more choppy and firmer feeling which I love as it's too comfy with stock wheels. Steering response is better but it does feel lighter which is a downside since it's too light already in Dynamic mode. It would have been perfect with the old Dynamic mode before the recent steering patch Audi did.
    Senior Member Three Rings kap09's Avatar
    Jun 22 2010
    2017 Grand Cherokee, 2015 Fiat 500e, 2016 eGolf, 1989 Jeep Wagoneer
    For me it was most noticeable under braking, but improvements were noticed all around.
    2014 S4 | DSG | Ibis White | Sport Diff | MMI | Carbon Atlas | B&O | Side Assist | SC Badged
    GIAC Stage 2 v2 | GIAC DSG | Roc-Euro Intake | AWE 102mm | Brembo 380mm | Deval Rear | OZ Leggera | Michelin PSS | OE Sport | AluKruez | H&R Sways | 40% Pinnacle Tint | Hoen Endurance | VCDS Mods | Escort 8500 x50
    Past Rides
    2013 S4 6MT//2010 A4 Quattro//2000 BMW 323i//1991 Integra//1990 Jetta//1993 Civic
    @kap9 on Instagram
    Senior Member Three Rings mact3333's Avatar
    Mar 13 2014
    Pacific NW
    There was a huge difference on how the car felt accelerating, braking and cornering when I lost 5 lbs per corner on wheels, 5 on tires, and maybe 10 on BBK...you lose 20 lbs per corner and it feels like you lost 300 lbs in unsprung weight...make scar feel like it weighs 3600 lbs....car doesnt feel heavy anymore.
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    Brake rotors have a fairly small diameter so they won't contribute a lot to rotational inertia. Generally speaking there are formulas and proofs done on the net you can look up that put a typical brake rotor inertia savings benefit of about 1.2x actual weight savings. So if you saved 5lbs per rotor it's like taking 6lbs out of the car for acceleration/braking.
    Wheels are a little more complex because diameters can vary a bit and weight can come from the tire and different places on the rim. Given the diameter is much larger vs a brake rotor, the gain should be more for rotational inertia but I don't have the "inertia to dead weight" conversion number handy. It's probably somewhere 1.6-2.0 I'd guess.
    I'd think it'd be noticeable if you got much lighter wheels, esp for suspension response as others stated.
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Jan 09 2008
    Winnipeg
    I wold love to see an instrumented test conducted during some other blind test where wheels are swapped several times without the driver knowing what is on the car and when. And have them document what they feel then compare to what was on the car and what the instruments say. I am not doubting that there is a difference but I know from my experience with getting a heavier tire (+4 lbs each which I figure is huge especially as the weight is so far out) installed I didn't feel anything that was significant. That said I wasn't out to conduct a test I just figured it would feel like driving a dump truck by what people say here. I figure I am just not that in tune with the car as others may be.
