Results 1 to 17 of 17
    Jul 28 2015
    Tire pressure reduction in RS5
    Ok, so the RS5 tire pressure is supposed to be 44F 41R - I don't know if it's my pressure gauge or what, but whenever I put air in the tires and fill them to capacity, I'm consistently losing pressure within a weeks time. I'm typically going from 44 to 40 in the front, and 41 to 37 rear. I should also point out that I have two sets of OEM wheels and tires and this happens regardless of whether I'm running snows (19" OEM with Dunlop Winter Sport), or summers (OEM 20" with Pirelli P-zero).
    I know tire pressure is dependent on numerous factors like weather, but this seems to happen regardless of temperature and I don't love the idea of running to the gas station for air every week.
    Anyone else experiencing this?
    Mar 18 2015
    2015 GL450
    IL
    Only thing I can think of if it is all tires and both sets of wheels is that you are driving to a gas station to use their air. Even in a short drive the tires heat up and your pressure readings at the gas station will be a few PSI higher than actual "at rest, cold" pressure.
    2016 S5 6MT - Brilliant Black, P+, High Gloss Black, Sport Dif, B&O, Tech, Nappa
    Engine: GIAC Stage 2 & SC Pulley / ECS Carbon S-Flow Intake
    Suspension & Wheels: H&R Street Performance Coilovers / Vorsteiner VFF-103 (Carbon Graphite)
    Exhaust: AWE Touring
    Cosmetic: OEM RS5 Grill / PPF & CQuartz Finest Coating / 35% Pinnacle Tint
    Jul 28 2015
    Yes - so to deal with that I'm parking the car during the day in a lot that's just a block away from a gas station, so I'm only traveling a very short distance to get air, and I'm also re-checking pressure at the station before filling the tires.
    Quote Originally Posted by RVJ View Post
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Temperature fluctuation causes tire pressure changes. Are the outside temperatures drastically different on the days you're checking your tire pressure?
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Jul 28 2015
    No - so far the NY winter has been almost non-existent, and the weather has been unseasonably warm (55-70), so there hasn't been any really serious variance in the weather so far, save for one or two colder days.
    Quote Originally Posted by HazeMyth View Post
    Jan 07 2011
    2013 C300 4Matic
    out of curiosity after it drops to 40 and 37, does it drop any further pass that if u leave it at those psi's?
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Mix some dish soap and water and squirt it around the tire where it sits in the rim and around the valve just to check if you're losing air through the bead.
    Jul 28 2015
    It might drop a little lower, but generally stays in that range.
    Senior Member Three Rings AirmattRS5's Avatar
    Jun 05 2014
    Irvine
    winter temp will have drastic affect on tire pressure. For every 10*F change in air temp, tire pressure will change by 2%.
    The name is Paul, not Matt // @rs_cinqo
    '14 Sepang Blue RS5 / Res-delete Sports Exhaust / Black Optics / Nav / Adaptive Cruise Control / KW H.A.S. / Forgestar F14 20x9.5 +22 offset / Huper Optik 30%
    Mar 18 2015
    2015 GL450
    IL
    Quote Originally Posted by PeregrineNYC View Post
    I assume that you're checking at the garage as well before you drive? Any variance between the two? Even a mile or two can heat up the tires enough to account for a couple of PSI. It's very strange because you've got a consistent issue across 8 wheels / tires.
    Jul 28 2015
    Hi, yes, I am definitely checking at the garage and then again at the gas station before and after (obviously) inflation. Maybe I should just get a decent tire inflator so I don't have to keep running to the gas station - anyone know of a decent one?
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Other than temperature fluctuations, sounds like you have a leak or improperly mounted tires. Have you checked your rims recently to make sure they are round? I lose about 1 psi per 2 weeks even if I go hard driving in the canyons.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Jul 28 2015
    Yes - had rims checked so we are good there. I think this will remain a mystery. I'm going to purchase a good tire inflator or compressor, or whatever they're called.
    Quote Originally Posted by superswiss View Post
    Jan 07 2013
    And get a good digital tire gauge. I have my own compressor, too. I check my tire pressure every other Saturday morning in my garage, before moving the car a single inch. That way everything cooled down over night and I always check it at about the same temperature. Here in NorCal, we don't have big temperature swings, so that works here, but in NYC you should leave the car outside for a bit and then check.
    Jul 28 2015
    If you like the compressor you use can you pass along the name? Thanks
    Jan 07 2013
    This one is what I'm using now. I just got it recently. My previous one died unannounced a few months ago. I like this one. It's very quick and easy to store away. The RS5 also comes with its own compressor in the trunk, but I don't know for how many cycles it is rated, so I keep it just for emergencies. Haven't had to use it so far.
    Jul 28 2015
    This looks great, thanks.
