My/Dad's car: 07 a4 cabriolet 2.0t
So I'll begin with how the recent issues with my car began.
About a month or two ago, a airbag light came on while adjusting one of the front two seats(both were adjusted so don't know which side is throwing the code).
I ran a quick search...it seemed to be a common problem with a wire that runs underneath the seat. Anyway, no fix was done since I went off to college and my parents were in the process of moving to Milwaukee from IL.
Now...came home for winter break and ordered a vagcom kkl(aftermarket) cable from amazon...and received it two days ago.
I spent some time yesterday using vcds lite and got it to communicate with the car but not the airbag module...i disregarded it as one of the limitations of the unregistered vcds lite program.
Anyways, my dad and I took the car out today and it was sending a esp and epc code that went away after a minute or two...So we come back to the car from shopping and we are heading to a restaurant...I realized that the esp and epc codes are staying lit and the car is in limp mode this time(by now im already cursing at myself since the car was fine before i tried to scan it the previous day
P0121-Throttle/Pedal Position Sensor A Circuit Range/Performance
P2101-Evaporative Emission System Leak Detection Pump Control Circuit Low
P0221-Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
(It threw a CEL on its way to autozone from the restaraunt)
While at Autozone, we disconnected the battery for 10-15 mins to try to reset the ecu...the cel went away,others stayed on and it had a rough idle but it made its way home.
After I ate dinner, I went back outside and tried to start it again but it wouldn't hold an idle the first time, the second time it held a very rough idle and there is a noticeable throttle response lag.
So I'm mad at myself, won't get good sleep tonight and don't know a trustworthy place to take it to tomorrow:
any input milwaukee members? I cant decide between north shore(audi dealership) and Autobahn Service Center (Independant shop)
