    Apr 27 2015
    Quebec/Qc/Canada
    Getting p0491 and p0492 on cold starts
    Hey did anybody experienced this? Im getting a CEL with codes P0491 and 492 only when it starts to get cold outside, didnt have any trouble this summer, it did it last winter and now came back.. weather is between 0 an - 5 celsius right now in canada
    Model B8 S4 2010 man
    Thank
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Check all the air lines.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Quote Originally Posted by psychodiver View Post
    Thank
    I have been getting them also. My Audi technician buddy said it could be the SAI pump going, it tends to happen in our cars. He said it only runs during the first 90 seconds of the car starting for emissions purposes, so even though you get a CEL, just clear it and move on. I haven't seen it for a few weeks now, but it was happening every few days. I'll keep posted.
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Mar 01 2006
    Kitchener, ON
    This just happened to me too - let me know what you come up with? I m going to be making an appointment myself
    I thought it was from carbon build up, however didn't do it all spring / summer / fall but started when the temperature severely dropped.
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Mar 01 2006
    Kitchener, ON
    Not sure if it will go anywhere...but yes same codes as what others were getting for carbon build-up, however it never tossed a code until the temperature dropped to -14 C. This morning when I started up the car I heard a loud buzzing noise coming from the driver side rear after popping the hood.
    Doing some searching, personally I might be ok in that I don't need to do the carbon clean-up (TD1'd after my warranty, found out late about the letter that came out from Audi grrrrr), but might just need a SAI rebuild / replacement = aftermarket warranty
    OP, not sure if you have any additional information besides codes pulled?
    Past
