Results 1 to 6 of 6
    Veteran Member Three Rings Krusty's Avatar
    Sep 19 2012
    long beach
    can a ross tech cable diagnose a faulty starter
    Before I put down the cash for a Ross Tech cable, wondering if it can help me diagnose a faulty starter. I'm assuming it's the starter, having some some issues during start.
    Jun 26 2012
    Rockford, il
    Quote Originally Posted by Krusty View Post
    I doubt it, maybe someone with more vag experience can confirm. You can always pull the starter and hook up 12v to it on a bench and see if it operates properly.
    Sep 19 2012
    long beach
    I don't have the space to do it, trying to cut my under the hood time. Thanks for the suggestion.
    Aug 03 2012
    Manitoba
    When my motor was seized, I got the following code using the cable to read the fault codes. If any codes are thrown the cable/software will pick them up. It's a lot of money to pay for a cable just to see if there is a code thrown, unless you plan on changing coding, logging TPMS enabling and all the other fun stuff you can do with the cable.
    1 Fault Found:
    10449 - Starter Will Not Turn
    P3054 00 [229] - Jammed or Electrical Malfunction
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 96819 km
    Date: 2015.09.04
    Time: 15:30:19
    Mar 21 2015
    You can use Carista if you just want to retrieve a code
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    Have your battery checked too. Their performance goes down with temperature and if it's having trouble on cold starts and it's 4-5yrs old, it's probably time for a new one.
    It could be the starter too and they usually go with mileage/use. I'd be a little surprised if it died under 60k miles but not impossible.
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
