Results 1 to 27 of 27
    Dec 13 2014
    columbus
    Touch screen radio install
    In trying to get rid of the old symphony radio and put in something a little more fancy this Christmas as a gift to myself. What are some good options for the 03 a4 1.8t? I'm not trying to go crazy expensive, just something with a little bit more appeal than the old symphony radio. I hear pioneer has some good ones around $200, but any links or suggestions would be awesome
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    I installed the Pioneer AVH-X2700BS. Also added the add-on nav unit and I'm pretty happy with it. If you get the Metra dash kit, make sure it all works before you fully seat the HU.
    The price goes up or down from there.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    Sep 17 2015
    United States
    very nice unit. is this a straight plug and pray or need extensive mod. ?
    sorry to hijack
    Aug 30 2013
    Rockville, MD
    There is a site that sells direct 1-1 wiring harness adapter that will plug into the stock harness and straight into the back of the radio for most radios. Unfortunately its quite expensive, but regardless if you check out enfig.com you can find what you need. You can always buy a spare pig tail and make the connections yourself if you are handy for much cheaper.
    Jan 10 2013
    03 A4 Avant 1.8TQ
    South San Francisco, CA
    For the whole system to run right you will need to spend about $300 on the enfig kit http://www.audizine.com/forum/showth...gCarStereo-com
    //Auto Union Bay Area : NCAC Member : Motoza Stage 1
    Apr 15 2014
    Ottawa/Gatineau Canada
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Is Mt s100 the name of that headunit?
    Apr 15 2014
    *my S100
    It is a s100...check the thread and the roadnav forums
    Senior Member Three Rings johnwiz's Avatar
    Sep 08 2012
    2021 RS5, 2004 Audi A4 USP
    Leesburg Va
    I got a Pioneer AVH-X5700BHS and used the Enfig audio harness and it was plug and play even with the Bose system. Only compliant, the FM reception is not as good as the factory radio even with the adapter. Otherwise a big improvement over the stock radio (I also have XM).
    2021 Ascari Launch Edition RS5, BC Forged RZ 21 (20 x 10 ET 22); 2004 Audi USP, B&B Sport Exhaust, VMR Rims, Stoptech BBK, Motoza Hybrid K04 Tune, ER Sport FMIC, Frankenturbo F21.
    Sep 08 2015
    Orting, WA
    I used the Metra and it was fairly straightforward. My car doesn't have an ACC position in the igniting switch, so it was necessary to tap into the fuse panel for ACC power. There's a few wires on the adapter aren't used. The red, and a blue for a power antenna.
    Because the Pioneer units listed are video players (DVD), there's a green wire that needs to be run to the handbrake switch. There's three wires... Two brown/white wires on one side (power side), and a brown in the other. You'll need to pick one of the power wires. But that's if you have a Quattro. I would imagine you would only have one brown/white and one brown if you do not.
    Dec 07 2015
    Wisconsin
    I actually ended up buying the Pioneer AVH270 BT Touch Screen from Crutchfield.com Wired up the harness last night and I believe I have one more wire connection to make and hopefully she will work. I mostly wanted it for the Bluetooth connectivity and the USB connection.
    Dec 07 2015
    Wisconsin
    Since my oem system worked with the car off I assumed I didn't need to splice into the fuse box. I afterwards learned that was because the oem system had the data wire. And since aftermarket units don't understand data wires that I need the use the supplied wire and wire it into the fuse box. Then it should work. I didn't wire in the green wire to the parking brake because I figured it's just a safety feature for watching DVD's. Does it NEED to be wired in? I know the blue wire for power antenna isn't used but the red wire is for power..?
    Senior Member Two Rings Dubbed-Out's Avatar
    Mar 13 2011
    MK2 GLI VR6, Mk1 gti, W212, C7 A6
    Quote Originally Posted by WB650 View Post
    for the Enfig
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    I went from a Kenwood touch screen to the RNS-E, even though it could be considered a downgrade with the Bluetooth and such. The RNSE looks so legit in the dash.
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Jan 10 2013
    03 A4 Avant 1.8TQ
    If you don't use the Enfig kit then you will not have rear speakers/"subwoofer"
    Dec 07 2015
    Wisconsin
    Why would crutch field design a harness that doesn't allow you to use rear speakers. I thought that's what the rca plugs were for
    If I could figure out how to post pics I show you how I wired mine up
    Jun 29 2014
    America
    Quote Originally Posted by 19jdog View Post
    Is it the newest version of RNS-e, the -193 part number?
    Sep 08 2015
    Orting, WA
    Quote Originally Posted by TSTUBB View Post
    The green wire absolutely needs to be wired in if you want to use the DVD.
    However, there are plenty of DIYs out there that tell you how to bypass it so you can use the DVD without having the handbrake engaged.
    Unfortunately, I found it only after I had pulled my console, ran the wire, then reassembled everything.
    Maybe when I do the B6 to B7 center console conversion.
    Sep 08 2015
    Orting, WA
    The Crutchfield harness does work for the rear speakers.
    Established Member Two Rings noldevin's Avatar
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    The crutchfield harness does work on the rear speakers but they will be a bit quietier than the fronts. Nothing a little fade can't fix. I will recommend getting the Enfig mounting kit, as the Metra cannot be removed after being installed. I have a spare Enfig dash kit if anyone wants it (I was able to squeeze my hand in back to get the sub plugged in and didn't need to remount).
    Veteran Member Three Rings POPO's Avatar
    Feb 02 2008
    2001 Chevy Tahoe, 2005 Audi A4, RIP 2003 Audi A4
    Somerset, NJ
    Quote Originally Posted by johnwiz View Post
    I have the same radio and same complaint as far as FM reception.
    2005 A4 2.0L Stroker- New South Vent Gauge|034 RSB|2.75" FMIC|GHL 2.5" Catback|PSi Concepts TD05H-20g|PSi Concepts Exhaust Manifold|Turbo XS EWG|Motoza tuned|
    RIP 2003 A4 1.8TQM
    Dec 07 2015
    Wisconsin
    After a week or two of using my system I have some feedback. First off yes, the Crutchfield harness works and uses RCA/AV plugs for the rear speakers. I cant get over how well the sock speakers work. The bass and sound quality is INCREDIABLE!! Also I was able to remove my system from the dash very carefully with a small blade screw driver, even thou every one says it's impossible. My rear antenna booster is cracked (common Audi problem) and I couldn't get shit for reception using the stock radio. Everyone says when you switch to an aftermarket deck your reception gets worse. Not true in my case. The aftermarket system makes the shitty cracked antenna booster sound like new. Also after having USB I realized how nice and handy it is vs. having to connect your phone to Bluetooth.
    Sep 17 2015
    United States
    can you list all items that you bought from Crutchfeld ? i would love to do the same but by reading the thread, i saw $300 add on in harness that make me cry. how Pioneer AVH270 BT work with steering wheel multi buttons? can you make use GPS and Make phone call via the radio screen ?
    Apr 07 2011
    Quote Originally Posted by audireme View Post
    Even the old one looks amazing compared to most aftermarket radios. Plus, what beats navigation directions in the instrument cluster? An option you will not find with an aftermarket radio.
    Jan 10 2013
    03 A4 Avant 1.8TQ
    FM reception sucks b/c our stock radios control the way the antenna uses it 3 antennas I believe, so without that the reception sucks. I actually left the antenna cable unplugged b/c reception was worse. If I move that antenna plug up near my rear view though reception is way better. I almost never listen to the radio anyways though so no biggie for me.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    I have a kenwood DDX371 I pulled from my B5 when it was totaled I'm looking to sell. 6.1 inch touch screen
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Dec 07 2015
    Wisconsin
    I purchased the AVH270BT Pioneer from Crutchfield.com. When you select your system you will have an option of adding everything else you need (removal tools, wiring harness, and dash install kit) You'll save $$$ by buying everything as one. I first added the wiring harness $30, removal tools$15, and dash kit $30 in my cart before adding the radio. Then I realized if you add the radio first it will find everything you need and include it as a "kit" I think I only paid like a couple bucks for the wiring harness and dash kit, and literally cents for the removal tools. Total bill was $210. The Radio was originally $280 but they had a sale so it was marked for $200.
