    Dec 13 2014
    columbus
    Replacement turbo questions
    So my mechanic told me my turbo is about finished, and been looking into getting a new one. I don't have a lot of money to spend at the moment, but I found this replacement one
    http://www.autopartswarehouse.com/sku/Audi/A4_Quattro/Replacement/Turbocharger/2003/Base/4_Cyl_1-dot-8L/REPA290106.html
    Would this be a good purchase for the money? I'm not that experienced w turbochargers. Open to any suggestions within a $400-600 range
    - - - Updated - - -
    Also I drive 03 Audi A4 1.8t
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    You can get an OEM BorgWarner within your budget, that would be a much better route than aftermarket in terms of longevity.
    2019 SQ5 Prestige
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Hey I've got a replacement K03 I just sent you a PM.
    Edit: Just followed your link. I would advise you to not go with an aftermarket chinese turbo. Stick to BorgWarner the OEM supplier of our K03 K04 turbos.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Established Member Two Rings dmanisgnarly's Avatar
    Nov 05 2014
    Supermotos & Sportbikes
    The East Coast, NC
    This would be a good time to go hybrid if you are after HP gains. FTG and Frankenturbo make the more popular K04 style choices. Otherwise, stick to a genuine Borg for $600
    2005 S4//K&N/Pod filter/Carbon MAF extension/APR Carbon NACA ram-air duct/JHM intake-mani spacers/Gutted piggies/Custom Catback/034 Motorsport billet engine mounts/19” Peelers/034 Snub/Neuspeed lowering springs/JHM stage 4 Kevlar clutch/Rallyarmor mudflaps/Rocketbunny V2 front diffuser/canards/HIDs/DRLs/LEDs/trailer hitch
    02' A4 1.8T Quattro
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Quote Originally Posted by dmanisgnarly View Post
    x2
    I have a oem borg k03 from my build let me know if you want it. no play no leaks 80k on it
    SOLD the GOINHAM A4 ---> GT2860 Project
