Results 1 to 6 of 6
    Jun 03 2011
    San Luis Obispo, California
    Any idea how to remove headlight switch knob from the switch assembly?
    Hello,
    Looking to replace the knob face on the headlight switch assembly. I was able to remove the switch assembly but can not F'n figure out how to remove the actual switch knob with all the worn plastic for replacement....
    Any ideas?
    Thank you !!!
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Two methods. The easiest way I have always done it to replace the knob is by cutting off the old knob with a pair of dykes. The other option is to remove the whole switch assembly using a small screw driver and pressing the two tabs from behind and then trying to remove it that way. Yes the cut method is untraditional but it can be done in 5 minutes.
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Jun 03 2011
    You're a savior I was contemplating that but chickend out now I know my destruction of that F'n knob is imminent!
    Thank you !!!
    Senior Member Two Rings frankwizzle's Avatar
    Oct 08 2008
    Derby City
    push the knob in and turn it left it should come out. Pretty sure there are youtube videos on it
    Jan 04 2013
    Zephyr Cove NV
    I want to saw a million swear words right now. I had no idea you could do that. In the past I had spent hours trying to stick a small screwdriver in from behind to push the tabs in.
    https://youtu.be/aW2zaJe80Xg
    Still tho, if you are just removing the outside knob, I don't know how else to get off the knob besides cutting it off. I just replaced the whole unit with a Chinese one from ebay for $12
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Jun 03 2011
    That is exactly the item I purchased. New plastic switch face and knob. Thank you for the tip!
