Alright so just bought this car about a week ago, got a good deal but has a few issues. Car says 148k but not sure if original cluster (doubt it). Apparently (just going by previous owner) the turbos have been replaced 20k miles ago, along with plugs and coils. The car has a GIAC stage 1 tune and has the cats removed. Not sure if all these issues are coming back to that (O2 sensors). There is a valve cover leak as well, which i plan on fixing ASAP. (Vac leak the problem?) The car shutters and loses all power under high load, then comes back but not very smooth. I got a VCDS and here's what it gave me. Any help with the immo would be great too but looks like i need a locksmith to find PIN.
Monday,21,December,2015,16:37:26:45199
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
VIN: WAULD64BX2N131794 License Plate:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 M
Component: 2.7l V6/5VT G 0002
Coding: 06711
Shop #: WSC 33278
VCID: 346910B9048BE09EA5-5178
10 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 -
16687 - Cylinder 3
P0303 - 35-00 - Misfire Detected
16686 - Cylinder 2
P0302 - 35-00 - Misfire Detected
16685 - Cylinder 1
P0301 - 35-00 - Misfire Detected
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-10 - Internal Resistance too High - Intermittent
16690 - Cylinder 6
P0306 - 35-00 - Misfire Detected
17539 - Oxygen (Lambda) Sensor; B2 S1
P1131 - 35-10 - Internal Resistance too High - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-10 - Malfunction in Circuit - Intermittent
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 35-10 - System too Lean - Intermittent
17585 - Bank2: O2 (Lambda) Correction Behind Catalyst
P1177 - 35-00 - Control Limit Reached
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 R
Component: ABS/ESP allrad 2330
Coding: 06395
Shop #: WSC 40708
VCID: 30611CA9F093DCBEC1-515A
1 Fault Found:
00526 - Brake Light Switch (F)
27-10 - Implausible Signal - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0103
Coding: 00003
Shop #: WSC 00000
VCID: 2D5F05DDE7A1B156EA-4B18
No fault code found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 02325
VCID: 5CB99819CC9B08DE4D-2592
1 Fault Found:
01592 - Air Quality Sensor (G238)
37-00 - Faulty
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 N
Component: Airbag 8.4E 5001
Coding: 0000307
Shop #: WSC 02325 785 00200
VCID: 3B7B3B8579D52FE664-515A
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02325
VCID: 2F631FD5EDADC346D8-522A
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 02264
Shop #: WSC 08839
VCID: 336B13A50185E7A6BC-5178
WAULD64BX2N131794 AUZ7Z0B2101494
2 Faults Found:
01176 - Key
65-10 - Unauthorized - Intermittent
01177 - Engine Control Unit
49-00 - No Communications
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D35
Coding: 15885
Shop #: WSC 46884
VCID: 30611CA9F093DCBEC1-4F3A
8 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01559 - Drivers Door
59-10 - Can't Unlock - Intermittent
01561 - Rear left door
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
VCID: 2C5908D9DCBBB85EFD-4B18
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
VCID: 264DFAF1C257820E2B-5178
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 F
Component: symphony II NP2 0051
Coding: 00201
Shop #: WSC 00003
VCID: 2A550EC1D64FA66E0F-4ECA
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 USA D08
Coding: 00126
Shop #: WSC 02325
VCID: 020586610EBF9E2E67-515A
End-------------------------(Elapsed Time: 04:29)--------------------------
