Results 1 to 4 of 4
    Senior Member Two Rings tomahawk297's Avatar
    Jul 25 2014
    Mississippi
    Question P2181 Code 2 weeks after turbo install?
    So today I got a CEL and smelled something through the air conditioning that smelled like coolant. Went to Oreillys and came up with the code P2181 which has something to do with coolant, I just installed a rebuilt turbo two weeks ago and did a coolant flush so I'm not sure what would be the most likely cause of my problem. Any knowledge and advice is much appreciated! Thanks.
    Mar 09 2007
    03 A4 1.8T
    Richmond%2C%20VA
    I was dealing with that for a while on my B6. It could be the coolant temp sensor in the back of the block (green sensor), or the faulty t-stat. Mine was a faulty t-stat. Code went away once I replaced the thermostat. Hope this helps.
    Zlaja
    Jul 25 2014
    Mississippi
    I'll probably just order the thermostat and CTS and replace them in hopes that it's one or the other.
