    Jan 12 2015
    Central Michigan
    1.8t Rebuild Questions
    Hi all, I'm rebuilding my 1.8 because I threw a rod at 210k. I've been doing a lot of research on different builds and I'm interested in getting a 2.0 Stroker kit with forged internals. My car is currently set up with a F21L Frankenturbo, 550cc injectors, and a eurodyne tune. I know I'd be fine with a stock rebuild, but I want to do it for piece of mind and for down the road. What I want to know is will the new 2.0 displacement require modifications to my tune or will I be able to run everything as it was. I also wouldn't mind running just upgraded internals with a stock displacement if there are any major red flags about the 2.0 Stroker kits. I know it's going to cost me, but I am prepared for that. I'm open to any reasonable suggestions.
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Sorry to hear this but I had to mention that every rod being thrown/motor blowing has had a Eurodyne/homebrew tune lately. I suggest when you rebuild pay for a qualitly tune from a professional. Well worth the cash.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Veteran Member Three Rings Audi body's Avatar
    Jan 03 2013
    bike and a pit bull powered pair of rollerblades!!
    the woodlands tx
    The 2.0 displacement will not effect your tune but the reason you threw a rod was most likely due to detonation. Best to figure out why this happened before risking your new block to the same fate.
    Jan 12 2015
    Central Michigan
    Quote Originally Posted by Audi body View Post
    Thanks for the input. I intend to look more into it when I tear the old block apart. This was a spontaneous event. There were no engine noises/warnings leading up it. However I question that it was because I might have been running too lean and too high of boost.
    Dec 05 2007
    There are many who can tune your car on this site. I have a b5 and had my car tuned by a b6 member. Driving on 5th revision till this day. Some charge, some do it it free off of pure enthusiasm (mine was free).
