Results 1 to 11 of 11
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Is this hose suppose to look like this?
    I came back from lunch just now to check the engine bay and found this hose shown in the pic. Is it ripped or suppose to be like that?
    Also it's an 02 A4 1.8TQ
    Sent from my iPhone in a secret volcano "lair"
    "Beep beeeep bloop boop" - R2D2
    Jun 08 2008
    Calgary AB Canada
    It's ripped.
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Oct 14 2011
    Norcross, GA
    Quote Originally Posted by onceover View Post
    It's ripped.
    Oh ok thanks! Do you know what it does? All I can find is that it's some air hose.
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    SAI pump to EGR valve hose/pipe. Replace it.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Jun 08 2008
    Calgary AB Canada
    That being said its not critical t the cars performance if you don't replace it immediately
    Stock. For now...
    Oct 14 2011
    Norcross, GA
    Quote Originally Posted by DiertyEuroSpec View Post
    That's good to hear, thanks for the replies! Just found the replacement and deciding on either 034 silicone hose or OEM.
    Mar 22 2010
    East Coast US
    Quote Originally Posted by WiLl2FLY View Post
    Or... find some one local that can del the sai for you ;) ;)
    edit: nevermind. for $10 I'd just get that hose.
    Established Member Two Rings yasiu_k's Avatar
    Mar 24 2015
    Yamaha FZ6
    I paid $12 for it from 034 website. Just my 2 cents.
    Established Member Two Rings Jborch8's Avatar
    Apr 30 2012
    Oil stains
    Issaquah, WA
    Go with 034. Silicone hose will last much longer.
    2005 A4 B6 1.8t Avant - Moro Blue
    Stage 1 APR Tuning / Eibach Pro Springs with Bilstein shocks
    Oct 14 2011
    Norcross, GA
    I was looking at silicone vs rubber hoses, and I might give 034 a whirl.
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    rip it out like a still beating heart from a sacrificial virgin. along with a lot of other stuff in the bay. look for a diy here 'engine bay delete' or something similar
