Not to hijack this thread, but I am having the same exact problem. I found the clicking to be the brake booster relay under the dash, so my suggestion would be to check that one out. In my current situation, I also found the small 15 amp fuse (#9) to be blown that it is tied into. I ordered a new relay thinking the relay was bad, put it in, as well as a new 15 amp fuse. The second I hit the gas pedal at idle, the fuse immediately blows, and the relay begins its song of clicking once again. Checked for vacuum leaks at idle by wiggling, as well as spraying soapy water, and nothing. New revised SJP is only a few thousand miles old, and has no hissing coming from it, and I verified it is still good. The only hissing I was able to hear at all was once I turned the car off. I could hear hissing from what appears to be behind the brake booster. Soo frustrating trying to figure this out.
