Results 1 to 12 of 12
    Dec 20 2015
    Alberta
    B7 S4 Whining from back of my car??
    So my car is currently at 105xxx KM and i just replaced the fuel pump with an oem, and for some odd reason the is a whining noise coming from where my fuel pump is. So my question would be is there a specific way to install the fuel pump or could there be some other problem I'm not aware of?
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 04 2014
    2009 Gray A3
    California
    I just did me fuel pump replacement and had a hell of a time getting the pump twisted onto the frame, until i realized it only fits one way, with the filter bag pointing in the direction of the right back passenger door. Once that was in properly, the cover and lock rung was straight forward. No noise from mine, so it might be worth checking the pump install again. Good luck.
    Sent from my SM-G920F using Tapatalk
    Nov 12 2015
    Oregon
    Are we talking loud whining or the normal whining you never notice unless you are listening for it? Did you change the filter when u did the pump?
    My build log
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Either way it doesnt sit right or your filter needs replacement. If you did new pump i would change fuel filter anyways.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Dec 20 2015
    Alberta
    Quote Originally Posted by VinnysS4 View Post
    its a loud whining noise, and it comes on at random. some days ill drive and not hear a sound, other days i hear a symphony coming from my back seat. and no i haven't changed my filter yet. but i can't see it causing the whining noise?
    Nov 12 2015
    Oregon
    I dont know why you needed to replace the pump, but it is possible that the filter is clogged and that is what caused the pump to fail initially. When you change the pump, it is always a good idea to change the filter. A clogged filter could cause the pump to work extra hard and make it sound like a dying cat. You may have just got a bad pump as well. Try to take the pump out and reinstall it. Make sure it is installed correctly. I cannot think of anything else it could be other then the filter or pump. just my .02
    My build log
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    i'd change the filter ASAP , it's relatively cheap compared to replacing a pump
    Dec 20 2015
    Alberta
    thank you guys for your input, i will change the filter asap. btw is the filter 1 in 2 out or 2 in 2 out?
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by sfourb7 View Post
    I'd suggest locating your filter to see if yours is a 4 line or 3 line variant , then buying the right one
    it's right in front of the rear passenger side tire , you can't miss it
    Dec 20 2015
    Alberta
    Quote Originally Posted by jakeoboy67 View Post
    Thank you =]
    Nov 12 2015
    Oregon
    yup i found a lot of different information on what filters the cars have. In the end, its right near the rear passenger tire and it takes like 20 seconds to see what one is in there. Better to just look and not have to return a filter.
    My build log
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    This!
    It should be required that whenever the fuel pump is replaced that the fuel filter is also replaced. Actually the shrew owner should change out the filter first to see if that solves a loud pump first and then change out the pump if problems persist.
