Results 1 to 17 of 17
    Jan 18 2015
    Suspension setup recommendation
    I posted this in the suspension sticky but thinking that thread probably doesn't get much traffic these days, apologies for the double post.
    Hey guys - looking for some recommendations. Car is a 2015 s5 with black optics wheels (ti rotors). Car will be getting a set of Bilstein coilovers, no new wheels. I'm open to getting some spacers to help clean up the look but I'm in need of some recommendations on ride height as well as alignment. Car is my dd and beyond a boring commute the most action it sees is freeway on ramps and interchanges with a possible trip through the canyons. I'll be doing the full ecode suspension suite (bars, end links, alu kreuz) at the same time.
    What do people recommend for ride height (ftg?) - I want zero chance of rubbing!
    What about wheel alignment - are most people going with factory alignment specs? I don't want to have to purchase adjustable upper control arms if I don't have to; I think my goal is somewhere in the 1-1.25" drop which I've read should mean no control arms necessary?
    Veteran Member Three Rings jamin_00's Avatar
    Sep 14 2014
    Essex, UK
    I dropped mine by 30mm running 20x10.5 rims and have no issues with rubbing on my PSS10's. I had the alignment done after install (highly recommended with any suspension change, regardless) and the fronts are out of the manufacturers recommended settings by a very small margin, but the tyre wear remains even it appears so is not causing any concern at this time (6 months)
    However time will tell but tbh I don't think they are not going to be needed.
    Audi S5 V6T 3.0 - Black Edition - Stage 2 MRC Tuning - 480bhp 580nm
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    I ran PSS10 and full Eurocode set up up on my 2011 S5. I settled on a 1" drop and had no issues with stock OEM split spoke wheels. You will need spacers though, the drop made the wheels appear more tucked in. I ran 15/20mm for perfect flush look. It looked great and no issues. It was also my DD.
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
    Mar 18 2015
    2015 GL450
    IL
    I've got the same wheels. Summer I run 26" FTG and Winter 27" FTG. Spacers are 15 front and 20 rear. Great stance and no rubbing at all.
    2016 S5 6MT - Brilliant Black, P+, High Gloss Black, Sport Dif, B&O, Tech, Nappa
    Engine: GIAC Stage 2 & SC Pulley / ECS Carbon S-Flow Intake
    Suspension & Wheels: H&R Street Performance Coilovers / Vorsteiner VFF-103 (Carbon Graphite)
    Exhaust: AWE Touring
    Cosmetic: OEM RS5 Grill / PPF & CQuartz Finest Coating / 35% Pinnacle Tint
    Sep 28 2010
    NW NC / DE
    1.25" and 15/20mm spacers, and you'll have no issues. If you EVER did rub, it would be in a dip, trunk full, and you'd only touch the rear carpet liner. As for alignment, you'll be able to get very close. Not worth the cost of the arms. I've always said, by the time you purchase the arms and install, I'm not sure you'll ever realize savings, even if you do loose say $75 in tread per set of tires. If that makes sense.
    Jan 18 2015
    Awesome thanks guys!
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    Very happy with my set up...you can see it in signature line. Virtually no rubbing, only on the biggest of bumps and like Mops said, its in the back on the liner. No big deal. I ran OEM wheels for a couple years with 15/20 spacers worked fine.
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Jan 18 2015
    Thanks guys - went with the recommended spacers and brought the car down to 26" FTG. Love the look and handles great!
    Is it normal that the rear wheel looks pushed toward the rear of the rear wheel well? <== scratch that, just a camera angle thing! Duh...
    Sep 28 2010
    NW NC / DE
    Looks good
    Mar 18 2015
    2015 GL450
    IL
    Looks great! Have to admit that it was a tough choice for me between black and the Sepang.
    Established Member Two Rings elmajiko's Avatar
    Oct 20 2010
    CYPRUS
    How is the ride with this set up?
    Jan 18 2015
    Quote Originally Posted by elmajiko View Post
    Quite well actually! The comfort mode is more comfortable than the factory S suspension and the sport mode is very composed in the turns. It's nice to be able to switch with the push of a button. The highways in California are not the greatest and there was a definite improvement in ride comfort.
    Sep 14 2014
    Essex, UK
    Awesome, looks much better :)
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    So if one did not want to run spacers, the rims would have an offset of 25? i have spacers now but when I get a new set of rims I don't want to run them. PITA with longer bolts, lining up etc.
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
    Jan 18 2015
    Quote Originally Posted by Canadianwraith View Post
    Depends on the wheel. I'm on stock black optic 19x9" wheels with a 33 et. Throw the 15/20 spacer on there and that shifts the offset by the same amount, so 18et front and 13 et rear. If you go +1" wider wheel then a 25et would make more sense.
    Dec 05 2010
    Sydney Australia
    Love the look - wish I'd gone for Sepang!! Thinking of having my Glacier White wrapped. On spacers, would 15/20 work with stock suspension and OEM 20" wheels?
    Jan 18 2015
    *probably? Better to let one of the more knowledgeable guys answer that question as I'm not sure what the 20" wheel option specs are.
