Results 1 to 3 of 3
    Senior Member Two Rings MrSnickelsnizer's Avatar
    Dec 03 2012
    michigan
    Rear deck/parcel shelf removal
    So real easy question. Has anyone removed the rear parcel shelf and driven around for a while? Beyond the guys who have,removed the shelf and welded in full cages.
    Reason for removal is to have,more storage area in car. Often transport a lot of stuff and parcel shelf gets in way more than not.
    So if someone has, do you need to weld a reinforcement bar in or is the rear glass and metal under rear glass enough to keep car stiff.
    And yes i will be getting an avant this summer so no need,to state the obvious. Thanks.
    1998 Audi A4 1.8t Quattro
    Nov 07 2010
    South of Heaven
    Most of the people who would do this are doing so because they have a cage and unless you are removing the seats as well you would not be gaining much space. It is a structural support so if you cut it out you should really be welding some bracing in to support that area.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Dec 03 2012
    michigan
    Bottom cushion is only part i have in currently. I figured bracing would be needed. Will have brackets welded on probably and bolt in a curved piece of tubing. Seems easiest. Just wondering if i am the only one to attempt it while it still being my daily driver.
