Results 1 to 20 of 20
Thread: Radio Code
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Radio Code
    Aside from calling AoA and providing vin and radio serial#, any way i can find the radio pin? My service and warranty manuals dont have any radio pins.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Local dealer? Other than that, no.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    May 20 2014
    e92
    I see radio codes being sold in eBay for about 20 bucks. Not sure about how they get it though.
    Jan 24 2013
    Chicago
    Quote Originally Posted by trj View Post
    Lol they probably cal AoA themselves. I heard encryption on the newer radios was tough to beat. On older radios they connect some pins to read the eeprom and software decrypts the pin.
    May 20 2014
    e92
    Quote Originally Posted by Denio24 View Post
    Probably. lol.
    May 11 2013
    Stupid question -- what are the downsides of not having a radio coded? I recently VAGCOM'ed my car, and the radio came up as being "not coded" or something similar. The radio was replaced by the dealer from the previous owner and everything seems to be working fine, FWIW.
    Dec 23 2011
    The radio will be in "safe" mode and won't work. Different issue then how it is coded in vcds to the car.
    May 11 2013
    The radio seems to work fine in my car, so safe to say it's a non-issue even though VAGCOM flagged it? On an unrelated note, where in Mass. are you p0ison? :D
    Dec 23 2011
    You'd see "safe" on the radio display and wouldn't be able to use it until the radio key is entered.
    I'm in Worcester, you?
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    I've been told; haven't verified, you can call AOA and give them any VIN and they will tell you the code. Doesn't matter if it was your car's or not.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    May 11 2013
    Quote Originally Posted by p0isin View Post
    Good to know. I'm in the South Shore.
    Jan 24 2013
    Chicago
    didn't realize AoA had 24/7 support.
    Dec 23 2011
    Quote Originally Posted by kerfuffle View Post
    Cool, that's not too far.
    Jan 24 2013
    Chicago
    Quote Originally Posted by JDillon15 View Post
    And actually i just tried this even though i had both the vin and radio serial, and the rep said i need both. I think this may be based upon how much he/she upholds security protocols.
    And a quick question, does anyone know the correct button combo to stop displaying safe so I can enter the code? For symphony 2+
    Jul 11 2014
    Chicago, IL
    So you were able to get the code? I bet you could call them back and get a different rep. I remember doing this on an insurance quote one time. It was my parents insurance (I had their permission to do this) and I was trying to figure out how much adding a car would change the price. They said I needed to be my father, so I called back and made sure this time I was my father. [LOL]
    Jan 24 2013
    Chicago
    Code has been received. Do you know the button combo to stop displaying "SAFE" so I can enter the code?
    Jul 11 2014
    Chicago, IL
    What unit is it? (RNS-e, symphony, etc)
    Jan 24 2013
    Chicago
    Symphony 2+
    She told me hold as & rds but there is none lol.
    Jan 24 2013
    Chicago
    I don't think there is a combo, you just have to wait, but my searching ventures have helped me find something better! LINK
    Veteran Member Four Rings Lastsummer's Avatar
    Nov 25 2011
    2021 B9 Audi SQ5 Black Optics
    Grayslake, IL
    If you hadnt checked already, there is usually a sticker located in your spare tire compartment if it has not been removed. The sticker with have the 4 digit code. Its how I found mine. I was informed by the service manager at the Audi Exchange.
    2021 B9 SQ5 - IE Turbo Inlet, IE CAI, 034 Motorsport Stage 1 ECU/Stage 2 TCU, O34 Strut Brace, 034 F/R Sway bars w/ end links, 034 trans bushing & insert, 034 RSF inserts, 034 rear diff inserts, 034 lowering links
    B8.5 Audi S4 - Monsoon Gray - EPL Stage 2 - Single Pulley, EPL TCU, ECS Carbon Intake, ECS Mid-pipe, Magnaflow Catback, ECS Drivetrain/Trans inserts, ECS Lower Control Arm Brace, CR-15, S5 Peelers, H&R sports, Bilstein Shocks
