Results 1 to 8 of 8
    Nov 29 2015
    2001 Allroad
    Texas
    Bad vibration starting at about 10 mph.
    I just replaced my engine. On my 2001 A6 2.7t Automatic . Got it all wrapped up and tried to go for a test drive. I got a really bad vibration that starts at about 10 mph. So needless to say I did not go very far.
    I noticed that my driver side CV has a torn boot.
    While disconnecting , reconnecting the drive shaft on the back of the transmission several of the ball bearings fell out. I cleaned them up and greased them up with CV grease, and put them back in. It was tight getting them back in.
    I did loosen the center mount. I did line it back up with the marks of where it was before.
    Someone with previous experience please let me know what your thoughts are to fix this issue. I need to be able to drive my car again.
    Thanks.
    Jun 10 2013
    United States
    Just reading the title inwould suspect drivetrain related. Most likely something with your driveshaft if it wasn't there before.
    Nov 29 2015
    2001 Allroad
    Texas
    Any one have a resolution?
    Apr 13 2014
    israel
    torque converter
    Use vagcon or another tool to scan gearbox.. and if any dtc
    Nov 29 2015
    2001 Allroad
    Texas
    Used vcds no codes.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    You could have assembled it wrong somehow, maybe didnt lube something up?
    Aug 04 2009
    Glen Ellyn, IL
    Just in case: do you have aftermarket wheels that require a hubcentric spacer? If so, did you lose one?
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Nov 29 2015
    2001 Allroad
    Texas
    I did Assemble it wrong. I sorted it out Monday.... I watched a youtube video on how to assemble a CV joint and saw what i was doing wrong. Vibration gone now.
