Results 1 to 8 of 8
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    O2 sensor was replaced twice, buy code comes back
    16514 - Oxygen (Lambda) Sensor B1 S1
    P0130 - 35-10 - Malfunction in Circuit - Intermittent
    Was blamed on ECU, so ECU was replaced too. Whats next to replace or troubleshoot?
    Aug 04 2013
    Pennsylvania
    You're replacing the correct sensor, right? B1S1 is passenger side, front sensor. You'll see it peaking down between the firewall and cylinder head.
    I ask because I just checked the ross tech wiki and it's weird they list possible causes as a faulty sensor and nothing else.
    I'm sure someone more helpful will chime in, but otherwise check wiring. Which, verifying power and ground and all that stuff should be done before replacing components anyways
    I'm like a tree. I'm all root
    May 16 2008
    WA
    also make sure that the sensor is being plugged into the correct plug. If they are flip flopped the ECU will be telling you the wrong physical location.
    Dec 04 2012
    Arlington VA
    my rears are coded out and yes, its passenger side. Will go and look at the wiring and connector one more time.
    Aug 04 2013
    Pennsylvania
    Quote Originally Posted by getslideways View Post
    Hadn't considered that although I just came across a TSB telling techs to mark which plug is which if they're disconnected lol
    Aug 06 2008
    Canadia
    I had a land rover that would throw o2 codes unless it had bosch sensors (didnt like NTK or universal) it also used bosch motronic ECU, so its worth noting.
    Maybe swap L&R sensors and see if the problem goes to the other bank, if so check continuity from ecu plug to sensor plug.
    - - - Updated - - -
    *meant to say "if not"
    Dec 04 2012
    Arlington VA
    Rear O2 sensor wire was touching downpipe and had insulation melted. It did not cause any codes, because my rears are coded out, but it shorted the ECU bus enough to cause intermittent code on the upstream sensor. Only code left now is 17965 - Charge Pressure Control P1557 - 35-00 - Positive Deviation
    Senior Member Three Rings audi-hammer's Avatar
    Aug 28 2009
    Buffalo,NY
    Hmmm interesting I'll have to check that out
    Silvia = 02 s4 stageIII
