Results 1 to 36 of 36
    Nov 29 2013
    Silver Spring, MD
    Tire Storage Rack
    I want to do better with my garage management (New Year's resolution, ha). The winter set is on and the summers are once again sitting in the corner taking up precious space (where other junk could be!). Just curious what other folks are doing: any old rack will do, built your own, or 'corners are my best friend'? FWIW, google led me to:
    http://www.tirerack.com/accessories/...IRERACK2_Qty=1
    http://www.griotsgarage.com/product/...torage+rack.do
    To be honest, they look exactly the same, yet there is $20 price difference on the griot. Just want to get one that I don't have to worry about it having come crashing down, lol. tia.
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Mar 21 2015
    It's only going to come crashing down if you don't mount it properly.
    Veteran Member Three Rings Tweakophyte's Avatar
    Feb 15 2012
    Boulder, CO
    You can look at the weight rating, but my guts says they are both the same. I got the tire rack one years ago. My only regret/concern is I need to climb a tall step stool (8') and carefully manage 50+ lbs without hurting myself or my wheels. A tire tree is much less expensive if you have the floor space.
    MY12 Ibis, Titanium, 6MT, Sport Diff, Leather, Prestige : 35% tint, AK, SC Badges... CPO (kind of a mod)
    RSNav (S4), CR15
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    Mine are stored in the storage covers and stacked in my shed for the winter...I would love to get the overhead mounts but will be getting on instead for other things like boxes and stuff that take up more room.....as was said the important thing is hitting those studs when mounting. If you do that you will be good to go!
    [B]Current: Shopping now....
    Nov 29 2013
    Silver Spring, MD
    now, where did i put my stud finder?!? lol, thanks, guys.
    Mar 21 2015
    Me ne neighbor has one mounted above his garage door and it is a little sketchy getting a set of wheels and tires up there from a ladder. It helps to have a second person hand you the wheels while you're already on the ladder.
    Mar 02 2009
    State of Confusion
    The same ones are on eBay last time that I checked...
    Oct 17 2014
    NorCal
    On your chest, but it has to be in front of your wife..
    Dec 07 2014
    Mn
    Mines from tire rack. There's another identical thread floating around with other pics and info.
    Sent from my HTC One_M8 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    Are the tires going to get flat spotted sitting like that for several months?
    Aug 30 2009
    Fredericksburg, VA
    Quote Originally Posted by Kczach View Post
    no...flat spots come from the weight of the vehicle no moving for long periods of time....with the weight removed there is no risk of the flat spots
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    I would actually recommend the Tire Rack one over the Griots one. All Griots does it find someone that already sells the rack, and then makes it for themselves.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Nov 06 2013
    Ohio
    Quote Originally Posted by Tweakophyte View Post
    This is what I was going to recommend. ECS sells a great one that you can move around your garage.
    Veteran Member Four Rings jareds941's Avatar
    Jan 12 2010
    Jackson, WY
    I have 2 of these: http://www.hyloft.com/heavy-duty-adjustable-tire-loft/
    no complaints about the racks. They've been up and doing their job for a few years now. As mentioned, navigating the wheels/tires up there can be a challenge. It is particularly challenging with the larger setup on the SQ5. I'm fairly young now...can't see myself managing it on my own 10 years from now...2nd set of hands is huge!
    Mine: 2021 Ford F150 PowerBoost
    Hers: 2016 Daytona Gray SQ5
    Previous:
    2004 E46 M3 Track Car
    2019 Daytona Gray S4
    2014 Glacier White S4
    2014 Glacier White SQ5
    2008 Daytona Gray RS4
    Senior Member Two Rings TehDolphin3.2's Avatar
    Aug 20 2009
    Long Island, NY
    I've had this one in my garage with stock 18" wheels and tires on it for over a year now. Nicely constructed. If you're looking to save a few bucks this is a nice option.
    http://www.globalindustrial.com/p/st...828aAn4E8P8HAQ
    Can be folded up when not in use.
    2013 S4 Premium+ S Tronic - Alu Kreuz - H&R OE Springs - BBS CH-R - Injen Intake - 034 Trans Mount Insert - Apikol Rear Diff Insert - 034 Rear Sway Bar/End Links - CR-15 Strut Bar - ECS Rear Diff Inserts - Milltek Exhaust - Carbon Imports Low Kick Spoiler
    Aug 12 2014
    Bexley, OH
    I have this one from Amazon: http://www.amazon.com/HyLoft-01012-T...ords=tire+rack
    It is easy to install and very sturdy. However, you have to mount it according to the stud placement in your garage. That made mine wide enough to fit about 5 tires. I just use the extra space to fit kid's car seats when we're not using them.
    Mar 21 2015
    Isn't an 8ft tall step stool considered a ladder?
    Mar 02 2009
    State of Confusion
    Nah. 8.5 feet surely is the cutoff from step stool to ladder...
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I have the tire rack wall mount unit. Easily installed it by myself. I would recommend trying your tire and wheels on it when its on the ground. Easier to adjust when its on the ground. Only pic i have is when it was empty.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    My dad put the Tirerack one up in their garage and loves it. He keeps 5 tires on it and it's never had trouble (one sitting on top).
    Junior Member Two Rings
    Nov 22 2014
    Cheshire, CT
    Sad story - I have this kind of rack but am not a big guy. Blew a disk putting up 21" wheels/tires. I'm not going to mount an electric hoist in my rafters to life wheels/tires from now on.
    - - - Updated - - -
    Sorry - I meant I'm NOW going to mount the hoist.
    May 12 2013
    B8 S4
    ATL
    Quote Originally Posted by Fife View Post
    I have this one as well, and I would recommend the others if you have an exact spot where you want the rack to be. I had to put the rack in a less than ideal location because that's where it would work with the studs.
    Jul 16 2012
    Mid-Atlantic
    I have the Tire Rack unit. It's sturdy and is easy to install.
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    I picked up one of these HERE/ since it's only $50 but wish I would have just gone with THIS and left it in the corner of the garage. The studs in my garage (where I want to mount it anyway) are ridiculous....not 16" on center and impossible to find making mounting this securely a challenge that I'm about to give up on.
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Veteran Member Three Rings 13allroad's Avatar
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    I have seen some people on the forum with amazing garages and tire storage solutions so if you have the space I would recommend the following:
    http://www.storevertical.com/product.../tire-carousel
    Current: Quantum Gray Metallic SQ5 / JB4 / Carbon Mirror covers
    Old:
    2014 A6 tdi prestige, HRE FF01 wrapped in Conti, black optic, sport package, LED package, RS7 Pedal Kit, 034 Trans mount, Alu Kreuz, Eurocode sway bars/end links, rear spoiler, Vag Com Mods, piggy back tune.
    2013 allroad tuned and modded.
    Weekend rider - 2015 BMW R Nine t - custom
    Sep 28 2010
    NW NC / DE
    Tire Storage Rack
    Exact same. Get the TR branded one. Griots is famous for selling re-labeled product across their entire line. Here is my TR one...
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Oct 14 2012
    Empty...for now...
    SE PA
    ^ x2
    SOLD 2015 Daytona Gray S4
    Established Member Two Rings wack0's Avatar
    Dec 12 2005
    Buffalo
    I have 2 of the red ones from ECS Tuning, but I might replace them with the TR ones because I don't like how my tires are just resting against my drywall. Also it doesn't feel very sturdy but I haven't had any issues with tires falling down.
    Mar 21 2015
    I'm loving that tool wall Mops!
    Feb 15 2012
    Boulder, CO
    On second look, it's maybe only 4 1/2' at the top step.
    ... looks something like this.
    RSNav (S4), CR15
    Mar 21 2015
    ^ That's better, lol
    Feb 15 2012
    Boulder, CO
    Quote Originally Posted by mjfloyd1 View Post
    PS My wife would not let me bring a ladder in the house... a large step stool is a different thing.
    RSNav (S4), CR15
    Nov 29 2013
    Silver Spring, MD
    Ordered
    Didn't know a new shop just opened up
    Sep 28 2010
    NW NC / DE
    Tire Storage Rack
    I'm a bit weird, and happy about it
    Quote Originally Posted by ptper View Post
    Ordered
    Work in progress, Sir. Floor went down last week. Floating cabinets go in Wednesday. Then the little things like wheels on the walls, painted German flag, metal prints etc.
    The TR piece is nice! Just make sure you have 5 studs (hehe) on the wall you intend to hang it. Because of my many windows, I only had access to 4 on that wall. I had to drill new holes, and ensure some measurements were dead-on, so still NBD, but 5 studs is preferred. Also, before you hang the wheels, measure and adjust the rack width. I did not, and had to pull the wheels right back off, which was not fun being its high up. I took the total, and added 2.5" on each side.
    Jun 18 2015
    Cleveland
    Quote Originally Posted by Usa View Post
    This...all day.
