Results 1 to 6 of 6
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    16514 - Oxygen (Lambda) Sensor B1 S1 P0130 - 35-10 - Malfunction in Circuit
    O2 sensor was replaced twice, and this error comes back:
    P0130 - 35-10 - Malfunction in Circuit - Intermittent
    Was blamed on ECU, so ECU was replaced too. Whats next to replace or troubleshoot?
    Jun 10 2013
    United States
    Check the wiring at the harness. I had an issue where a wire came loose from the pin in the harness. Seems like it was not crimoed properly at the factory.
    Dec 04 2012
    Arlington VA
    It was not a loose wire, but it got me moved in the right direction. Rear O2 sensor wire was touching downpipe and had insulation melted. It did not cause any codes, because my rears are coded out, but it shorted the ECU bus enough to cause intermittent code on the upstream sensor.
    only code left now is 17965 - Charge Pressure Control
    P1557 - 35-00 - Positive Deviation
    Oct 13 2015
    Omaha, NE
    GOOD! You need some sort of progress after the nightmare you've had
    I assume the misfires are still present?
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by twizz View Post
    I am knocking on wood as hard as I can, but so far 0 misfires in over 300 miles I put on the car yesterday.
    Oct 02 2013
    05 allroad FBP 6mt, 06 VW Passat Komfort, 08 VW Touareg V8 FSI
    pennsylvania
    That's great news! I felt for ya!
