Results 1 to 7 of 7
    Jun 03 2011
    San Luis Obispo, California
    Any inexpensive options to brighten the allroad stop lights and turn signals?
    Hello everybody,
    I installed some new reverse LED bulbs http://www.ebay.com/itm/80W-High-Pow...tV1E-x&vxp=mtr
    and was very impressed with the amount of light. I'd like to do a similar upgrade to the stop and turn bulbs but I'm concerned because the LED's usually throw errors and have blinking issues.
    So I found some options that looked error free, inexpensive and worthy of the time. I wanted to get your opinion on whether or not I will have error or blinking issues with the propose set up.
    I was looking to use these as resistors to avoid errors and blinking issues: http://www.aliexpress.com/item/1156-...562835664.html
    Anyone have inexperience with trying to use LED's in the stop lights? My intention is to improve the safety/visibilty of the rear of the car.
    I wonder how the LED bulb will react when the brakes are pressed, would the LED know to become brighter when the brake pressed?
    Thanks for the help and I hope this helps anyone else attempting a similar upgrade :)
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    modifying blinker relay is a better option than these hot resistors.
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    is there an electronic blinker relay available for our cars so we can swap LEDs in as we please?
    2007 A6 Avant 3.2L Black/Black, 265k miles
    Jan 19 2014
    b5 a4 1.8tq
    New York
    the relay is the hazard switch on your dash
    Jan 16 2009
    oh right i forgot already, i just swapped that part out a few months ago too.. Vinny do you have a mod thread for that to reference?
    OP: As far as brake lights, they are 1157 bulbs so they have two prongs, one for normal tail light, one for brake light. two different circuits, that is how they get brighter.
    Marko
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by estomax View Post
    Marko
    http://www.audizine.com/forum/showth...9-mod-tutorial
    tutorial is great, but LEDs OP uses look crappy even for 2013, there are much 1157 LED's available now. Also consider white/amber switchback if you removed your amber corners already or considering to do so, maybe something like this:
    http://www.ebay.com/itm/1set-1157-12...-/262202923872
    Jan 16 2009
    hmm it says the face lift relay is already electronic? i thought i already tested and it still flashed fast.
