Originally Posted by
kalch
i think i like your idea better. no need to get power into my glove. just attach my phone to the RCA/HDMI-LIGHTNING set-up, right?
Worth a try with a lightning to HDMI adapter, then HDMI to RCA, then the RCA to MMI cable. That's a lot of adapters...not sure what the losses look like in all that.
You also have visible wiring from the cockpit to the glove box. An Apple TV gives you a wireless Airplay solution. I am considering mounting the inverter and Apple TV in the trunk in the MMI rack and routing only the rca cables to the glove box and running Airplay on as required. No remote needed under normal circumstances (airplay mirroring)...I can also use the remote app on my phone when absolutely required.
