Results 1 to 11 of 11
Thread: suspension time
    Apr 01 2005
    one wagon one truck
    Michigan
    suspension time
    Ive got an 03 a4 with about 165k miles. I need some new suspension parts(to many trips to the Home depot). Do I need to do the shocks only or shocks and springs? What is the cheapest option to go with? I dont need coil overs and am just looking for a good sporty day to day setup.
    2009 Audi A4 avant, ECS CAI, Malone stage 2 tune, etc.
    1995 Mazda Miata Montego blue with tan
    2003 A4 1.8tqms Mototec Cold air intake, USP door Blades, GIAC software and bigger injectors. - Gone
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    springs are fine as long as you don't want to lower them. I would look at all the other stuff though like control arms and spring seats. all that rubber if you are still running the OEM stuff is probably shot.
    2003 A4 1.8T Quattro Auto, Custom Stage1 tune, N70, 550cc Fuel Injectors, B7 console (with cup holders!)
    Apr 01 2005
    one wagon one truck
    Michigan
    I have new control arm kit but I am sure the stock sport shocks are finally gone. So I am looking for a good replacement option instead of stock.
    Aug 27 2013
    Philly
    Quote Originally Posted by jaustin View Post
    Koni seems to be the go to setup for most people. I run the Koni Yellows, other run the FSD's, which are like 20% more expensive than the yellows, but they are self adjusting. I've had my Koni Yellow's for about 18 months now and I've liked them. Sure the ride is somewhat stiff, but thats because I adjusted them that way to fight the car from diving when turning or braking.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Bilsteins FTW.
    2019 SQ5 Prestige
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    If you have the OEM Sport suspension, check to make sure the springs are ok and not cracked. If they're good, then you only need to replace the struts. Bilsteins are a great replacement to the OEM struts. They're on sale now over at ECS Tuning.
    Clicky click
    USP CLUB MEMBER #34
    Apr 01 2005
    one wagon one truck
    Michigan
    ^ when you say cracked you mean just hairline cracking or do you mean broken crack?
    Oct 02 2006
    Wadsworth,OH
    If there's a hair line crack it will eventually lead to a broken spring. Better to replace it now if its showing a hair line crack then to have a busted spring later on requiring more labor.
    Jason
    Apr 01 2005
    one wagon one truck
    Michigan
    I doubt I have any cracks I live in MI. and the reads are in rough shape. So a crack would be a break./
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    I will second the bilstein suggsstion. Mine have been great for over 2 years.
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Apr 01 2005
    one wagon one truck
    Michigan
    I mistyped my first post I have 26-.--- miles
