Thread: Help
    Dec 19 2015
    Mount Vernon, NY
    Help
    Car was running low on oil. Stopped, changed the oil, then started to get these sounds. Car is an automatic won't accelerate at all, but will drive. Brakes aren't as strong sometimes. I went to autozone and it said to replace the camshaft adjuster solenoid, also getting codes for turbo under boost. Check engine light is on, what is my next step?
    Jun 17 2013
    jersey city nj
    the cam follower off the hpfp and at it
    May 07 2015
    United States
    Dont know if you have read in to the extended warranty on the Camshaft/follower/HPFP on these vehicles, what year is yours?
    http://www.audizine.com/forum/showth...-reimbursement
    Theres the range of VIN's
    May 07 2015
    United States
    Sounds like something may have happened within there, if the follower wears all the way through the metal could wind up in the timing/oil system if im under the right impression.
    Dec 19 2015
    Mount Vernon, NY
    Quote Originally Posted by Seanyjonny View Post
    2007 thank you
