Results 1 to 4 of 4
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Will a 235/45/17 be ok for my spare tire w a set of 225/50/17s?
    Im ready to put on the snow tires for snowboarding season.....I found a perfect wheel match but the tire is slightly off. Is this ok? Or is the 45 aspect ratio vs the 50 going to be an issue with the wheel size and the Quattro system. I'm assuming that the slightly wider 235 vs the 225 isn't a real issue? Can I safely use the tire if I need to do so in an emergency without damaging the car?
    Dec 14 2011
    Chagrin Falls, Ohio
    Easy to google a tire size chart to see the difference, but the difference in diameter is about 2% and about 16.37 revs per mile. Should be ok for emergency use.
    Veteran Member Four Rings Samsonite's Avatar
    Apr 15 2013
    Golf Clubs
    Minnesota
    Yep looks to be 2.4%.
    https://tiresize.com/calculator/
    Of course different tire brands/models can vary even in the same size, but you will be fine.
    2020 Range Rover Sport • HSE Dynamic • SC 5.0 V8 • Santorini Black
    2016 S6 • Ibis White • Black Optic • Sport Pckg • APR TCU/ECU Stage 3
    2013 S6 • Phantom Black • Sport Diff • Revo Stage 2
    2013 Q7 S-line 3.0T • Glacier White • Sport Pckg
    2011 S4 6MT • Ibis White • Black Optic • Sport Diff
    2008 A4 S-line Avant 2.0T 6MT • Ibis White • APR Stage 2
    2008 A4 S-line Avant 2.0T • Dolphin Grey
    2005 A4 Ultrasport 3.0 6MT • Dolphin Grey
    Jun 15 2011
    Exiled.......
    Thanks guys! New wheel, new Continental $60. Works for me!
