Results 1 to 6 of 6
    Established Member Two Rings B5Riches's Avatar
    Dec 15 2015
    Bayside, NY NYC
    Interior dashboard trim removal
    Hello Audizine
    ANy instructions on how to remove the interior trim on the dashboard part above the cup holder?
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    Its kind of difficult to get to, there's a series of clips along the back of the trim holding it to the dash. You'd have to remove the glove box, driver side knee level trim and probably centre Console.
    I wrapped mine whilst I pulled the dash out when changing heater core, much easier to remove it with the dash out
    Sent from my E6653 using Tapatalk
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
    Sep 25 2015
    Wisconsin
    Quote Originally Posted by B5Riches View Post
    Hello Audizine
    To remove the wooden trim looking design piece made of metal you must remove your factory radio and then you should see two two 8 millimeter bolts, after those there are tabs that just need to be pulled out.
    Sep 13 2012
    Adelaide, AU
    Quote Originally Posted by monster232 View Post
    You're 100% correct if op was referring to the radio/hvac trim but I believe he meant the Beltline trim.
    Sep 25 2015
    Wisconsin
    Quote Originally Posted by down_n_dapper View Post
    Where would the betline trim be located in the car, just curious?
    Sep 13 2012
    Adelaide, AU
    It's the uniform trim running across the dash and doors, called Beltline :)
