My 2000 threw some codes. Just to let you know, I've done searches on this and only came up with a torn TBB for the p1157.
P1557 (Charge Pressure Control - Pos Dev)
P1137 (Bank 2 (add) System too rich).
My car has these upgrades:
APR stg 2
APR Bi-Pipe
stock DVs (tested and are working fine)
034 3 inch Dps
rear o2s coded out
EVAP "coded out"
NEW primary o2s
The car has a rough idle, and my boost gauge would sometimes drop to -15 vac from the normal -18/-19 vac. I feel the car lost some boost pressure as well. The car holds 13 psi under full load. The car is chipped with apr stg 2.
I performed a boost leak test at 15 psi, and i noticed that my N249 check valve was leaking out of the check valve seams after i sprayed some soapy water on it. I sprayed the green check valves as well and they seem to be fine. But i will check them more thoroughly. Would that leak in the N249 check valve cause the codes i listed above?
I ordered the new n249 check valve and will be throwing that in on sat. My EVAP system is "coded out" based on what the previous owner says, but when i run the readiness it says its ok. Also I also tested the N80 in vag and it works fine.
I checked my fuel trims in (032) as well as (033). The long term fuel trims were sitting at -3.1% and -4.9% (in order from first block) and the short term fuel trim (033) were fluctuating between + and - 2% on each at idle. I sprayed brake clean around all vacuum lines and other possible areas to see if the fuel trims will change, but nothing changed the values. I disconnected the Maf and the values changed dramatically as well as throwing a code.
Any help on this would be great. Thank you
