Originally Posted by
AllroadCorbin
Perhaps I dont know enough about the strength of the DSG transmission but theres no way the stock DSG that comes with these cars will last long with this much power/TQ. I'm curious to know more about what these DSGs can handle/ what (if anything APR would need to do to make that work). I feel like it would be pretty easy to fortify the manual box to handle the power but the DSG? I'm curious....especially since the S3 doesnt offer the manual. Very fascinated by this upcoming release
The DQ250 is an interesting little transmission. It's not rated for too much torque but people have been abusing the hell out of them for a long time. Based on hybrid turbo applications oversea's limiting torque to sub 450 ft lbs seems to keep the stock clutches from slipping under high load conditions with a TCU tune. Anything beyond that will probably cause premature failure of the clutches. The physical transmission itself isn't the problem, upgraded clutches solve the issue. But, they are limited suppliers SSP, they are expensive, many shops wont touch them and they are very delicate to install and balance properly and the TCU has to adapt to them.
So you'll probably see even with the most aggressive E85 tune torque limited and peak horsepower at higher rpm increased based on octane and timing. I wouldn't be surprised to see a Stage 3+ with 450 ft lbs and 500+ bhp up top while still being "relatively" safe.
