Results 1 to 12 of 12
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    Automatic Wipers add-on Solution?
    Obviously our cars didn't come with an automatic or rain sensing wiper system, but has anyone looked into a retrofit from a different model or possible a aftermarket solution? So far I haven't found much of anything.
    Yes, I live in Seattle so I'm sure you can understand why I'm asking.
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    You're crazy.
    I'm sure there is as this technology has been around for a long time. I just can't imagine having the desire to pay for it, wire it up, and have yet another electrical sensor that will go bad. but to each their own.
    Aug 24 2014
    Newport Beach, CA
    It's probably possible, but it's not going to be easy without significant wiring. What I'd recommend over anything else is coating your glass with any number of glass coatings which will allow the water to fly off the glass and keep things much clearer even in pouring rain. Some options:
    - Opti Glass (best out there IMO)
    - CarPro flyby30
    - RainX (not as durable)
    The better coatings out there like Opti Glass can last for years, and you can look up how it performs on youtube if videos help.
    2024 M3 Comp xDrive
    Sep 13 2014
    Land Cruiser HDJ81
    It's nice, but there is no way I would go to the trouble to install it.
    2000 B5 S4, Laser Red
    Aug 06 2008
    Canadia
    I just wish the wipers were on, they would automatically go to intermittent when the car was stopped like bmw has been doing since the early 90's
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Quote Originally Posted by MacDaddy View Post
    They [Audi] gave the driver full control. The way it should be.
    May 16 2008
    WA
    Quote Originally Posted by mys4.org View Post
    from a fellow PNW'r who sees plenty of rain... I hate them, and everyone else I know who has the Audi or VW rain sensors does too. My touareg has them and its never just the right speed or timing. I much prefer being able to set them on my own and adjust accordingly. Now the comfort blink module retrofit... that would be worth retrofitting IMO
    Veteran Member Three Rings rnagy86's Avatar
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Some Golf Mk IV has factory rain sensors, from that chassis you can easily retro-fit.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by getslideways View Post
    That's a pretty easy retrofit, on my list of things to do eventually:
    http://www.audizine.com/forum/showth...Mod-(3-Blinks)
    Quote Originally Posted by rnagy86 View Post
    That's a popular mod in the Golf and Passat world, but it's more of a plug and play for them since it has those capabilities but VW only installed automatic sensors in a small number of those model years.
    2024 M3 Comp xDrive
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by christianb5s4 View Post
    You could do that 3 blink retrofit with 2 dei pulse timers. They are $15. It's a simple relay that holds charge for a timed amount(adjustable with a screwdriver.
    You could place it anywhere inline between stalk and whatever takes the input to make the turn sigs blink. Then adjust it to run the exact time of 3 blinks. You'd essentially run each on each side of the car and wire it so that if the opposite side gets triggered (a wanted cancel is invoked) it will cut power to the running timer.
    I'll have order a couple and make a diy
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    it rains so much there just leave the wipers on forever. its basically what will happen with a sensor anyway.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    May 16 2008
    WA
    Quote Originally Posted by vavJETTAw36 View Post
    Please do!
    I was trying to figure out a way to allow that to operate in the manner you described, but was going about it all wrong. I didnt even consider the components you mentioned. Looking forward to your writeup
