Results 1 to 14 of 14
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Any way to get the steering wheel scroll to change audio track?
    In my b7, the setup was almost identical except the scroll changed the audio track. no dice in the SQ... anyone able to hack this together? I'm willing to go the distance on this, lol.
    Anyone know if this works in any other B8.5's? A5/S5/RS5
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Both of my SQ5's scroll through audio tracks with the left scroll wheel. I didn't have to do anything. In fact, scrolling it at any time changes the DIS to the audio tracks. Pressing it selects the track you're on. Either yours is jacked up, or I'm misunderstanding your question.
    Mar 07 2004
    '14 Q5 TDI Prestige & '14 Q5 TDI Premium Plus
    Charleston, W.V.
    Scroll and press in.
    Veteran Member Three Rings Adplaya's Avatar
    Apr 25 2015
    TEXAS
    Wait...for BT too? Feel like left scroll changes modes, or something?
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Quote Originally Posted by SQive View Post
    Quote Originally Posted by BarryT82 View Post
    Quote Originally Posted by Adplaya View Post
    damnit, i think we found the problem. I guess this works just not for BT audio?? holy shit that is pathetic. sadface.png.
    if you can change BT tracks from the button by the shifter... i don't get why you can't change tracks on the steering wheel. hoping mine is jacked up, but this was the case in 2-3 that i test drove before buying. so I'm thinking its probably a restriction on bluetooth audio
    did some searching around... looks like its not possible for BT audio. wow that is a colossal fuck up by audi... time to jimmy rig something to work lol.
    Mar 07 2004
    Charleston, W.V.
    I'll try mine when I get in the car. It may only work on playlists with Bluetooth.
    Apr 25 2015
    TEXAS
    Confirmed doesn't work for playlists either over BT. Used Spotify playlist if that matters.
    Mythos Black on Black SQ5
    H&R springs - CF Mirrors - Eurocode Transmission Mount - Black Diamond AWE Touring Exhaust - Hardwired V1 (for the haters) - LaminX
    - 15/20 Spulen Spacers - Thinkware F750 2CH DashCam - 034 Rear Sway Bar and End Links
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    yeah doesn't work for iphone music app
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    My solution was to copy my music to an SD card. Albums are separate folders, then I made a playlist folder replicating my phones playlist I always play. Then you select random or not. I feel the random audi mmi is better random than apples choices. It loads far faster, you can scroll and select with the wheel, and if you have album art it shows up as well if you like.
    When I tried to copy this sd card music to the MMI it resorted it and some album art went away. I like the album browser function of the mmi, but most of the time I play my playlist and select from that.
    Steve
    '15 SQ Monsoon
    Veteran Member Four Rings jomama229's Avatar
    Jun 07 2013
    orange county, ca
    Quote Originally Posted by drumnjuny View Post
    i'm not a big fan of the 2 thumbwheels on the steering wheel. i much prefer to reach down/over with my right hand and toggle the volume switch left/right to change tracks.
    2014 Q5 3.0T Glacier White Metallic - 034 Stage 2 / TCU - Bilstein B8/H&R
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    I just called Ingolstadt. They've stopped all work on DieselGate and have allocated every resource to correct this colossal fuck up. Yes we can.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Jul 12 2014
    _
    Quote Originally Posted by jomama229 View Post
    I totally agree with this. I'd rather rest my elbow on the center arm rest and use the MMI's center console volume/track/play/pause knob.
    Nov 09 2015
    Ventura County, CA
    I tried voice command "next track", and that worked on Pandora thru my Android phone.
    Apr 26 2014
    DFW
    Quote Originally Posted by VroomVroom View Post
    LOL
