Results 1 to 28 of 28
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    Help!! car cranks really long then starts
    hi this is Joe, I have a question for the zine.
    When I start my car it takes 4 -5 seconds to start. Cranks cranks cranks thrn finally it starts. After sitting for an hour or so it does the same thing. But if I start it and turn it off then start it again, it starts back up rite away in 1 second .I have no codes, I have had this issue since my 044 fuel pump was installed like 5 years ago I think!
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    You could add a check valve to keep the fuel in the fuel line coming from the tank, or you could also try priming ur car before starting it(key forward for 5 Seconds then back to off then back forward for 5 Seconds and then try starting)
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    where can I get a check valve from ?
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    I have herd of this before and I feel like this is the problem
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    You're losing fuel pressure. If you put the car in accessory for several seconds before you crank to prime it, does it start right up?
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    Yes it will start rite up I feel like u gues are rite what's the check valve look like so I can put this in !
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    I have this issue. I had an 044 now a lph450 pump. Changed my crank sensor, FPR, & coolant temp sesnor. Sometimes my first crank starts it up right away sometimes not. Problem normally exists after I drive it and start it up about an hour or so later. I'm lost, sounds similar. In for suggestions.
    I am stage 3 - doesn't happen on my e85 tune, Idk if you are tuned but I have read my 93 fuel trims are probably off during warm start - I've played with lemmi but still did not help.
    Sent from my SCH-I545 using Tapatalk
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Feb 24 2010
    Oregon, Ohio 43616
    You may want to make sure you don't have a leak somewhere near the engine that could cause a fire at some point.
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    https://store.034motorsport.com/bill...lications.html
    It says it comes with the check valve which one is it ?
    Feb 17 2006
    Coastal Georgia
    Seeing bad gas mileage? Smell fuel at all? Could be a leaky injector. Seen this happen before with same symptoms you have.
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2000 C5 4.2Q - Sold
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    No gass is fine and injectors are new happened with my old ones as well. No smells
    Sep 11 2009
    NE
    Like said above, since your problem started right after 044 installation, somebody forgot to install a in-line check valve so you're losing fuel pressure. Unlike virtually all aftermarket pumps on the market, 044 doesn't have a built in check valve.
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    Yes I agree with this where can I buy this check valve
    Sep 11 2009
    NE
    this might work, but ask 034 first:
    https://store.034motorsport.com/fitt...p-adapter.html
    Aug 24 2014
    Newport Beach, CA
    I have the same issue, I bought this one which is the OEM 044 check valve. Haven't had a chance to install yet.
    http://www.amazon.com/gp/product/B00...ilpage_o01_s00
    2024 M3 Comp xDrive
    Aug 24 2014
    Newport Beach, CA
    Another cause could be a vacuum leak, to confirm you need to look your long term fuel trims on vag-com. If they are over +/-10%, could be an indication of a leak assuming your fueling isn't an issue. However, if the check valve is bad I could see that being a hindrance to fuel flow so that could also cause problems.
    I'm installing my new check valve next week so will report back.
    2024 M3 Comp xDrive
    My car has had the same issue since install. Recently found a pin hole size leak in the fuel line outlet at the pump allowing it to bleed off pressure. Replaced the line and it now starts after a half a crank everytime.
    Aug 30 2007
    nyc
    use the 044 check valve, i got mine from 034 its now on my fuel filter and keeps my pressure fuel up!!! i have a walboro 450 btw
    c5 A6 tip
    this n that
    Veteran Member Four Rings treysgreen's Avatar
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    Mine does it too on a cold start. Just turn the key on for a few seconds before trying to turn it over.
    02 A4 5spd 1.8T Quattro ///
    01 S4 6MT /// - SOLD
    Instagram - s4mods ///
    http://s4mods.com ///
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    Ok so I bought an inline checkvalve for the soft line outside the fuel pump and also a new check valve kit from 034.
    This should do the trick!
    http://www.amazon.com/gp/aw/d/B01862...el+check+valve
    https://store.034motorsport.com/bill...osch-60mm.html
    http://www.bmwe34.net/E34main/Trouble/535ihot_start.htm
    Aug 24 2014
    Newport Beach, CA
    Nice, I saw that BMW DIY too but I don't want the check valve already in there to stay in especially if it's not functioning properly. So I'm going to use the Bosch check valve and keep in the original location.
    2024 M3 Comp xDrive
    Sep 23 2007
    Get the cap in this DIY. A legit 044 should already have the check-valve built in. Just need the cap
    http://forums.quattroworld.com/a4/msgs/85051.phtml
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    Quote Originally Posted by kingofqueenz788 View Post
    have you ever replaced the fuel filter??? just a thought
    2008 Ibis RS4....GETing tuned
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    All fixed ;$
    Aug 04 2014
    Gloucester MA USA
    All fixed ;$
    Added a check valve? Or was there a problem
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Maybe dude is a wizard
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jan 31 2008
    All fixed ;$
    What was the fix?
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    The hose clamp on the fuel pump was not holding pressure
