I was hoping someone else has run across this before and can share experiences. My 2014 S7 had the APR ecu/tcu tune, milltek full exhaust with no cats, and intake and at the top of first gear under full throttle it absolutely falls on it's face.
It is extremely pronounced if i launch the car like it is bogging down from being way too rich or not firing at all. It is with the car warm at full throttle or cooler at 3/4 it stutters at nearly the top of the gear.
The APR mobile shows two lines in DTC but they both state that the code wasn't found in all three description lines and there is not a number associated with either of them.
This happens nearly every time in first gear under load (read boost) and I'm trying to figure out how I can diagnose or if it might be a common issue.
Thanks for the help as always!
