Aux fan is fixed.
Tim.
If anyone is seriously interested in the vehicle let me know. Reasonable with price.
1/7/2015
S4 rims installed, near new snow tires installed.
4 wheel alignment done
SERVICE HISTORY AS OF 1/9/2016
OWNER #3:
157,8XX 1/9/2016 PURCHASED, HAS YET TO BE SHIPPED+INSTALLED OEM Coolant expansion tank, S6 Front Grille emblem, S6 Rear Trunk emblem, N80 Purge Valve, Aerial Mast Rod Antenna - $204.72
157,515 1/7/2016 Four wheel Alignment - $86.40
156,950 12/25/2015 Auxiliary Fan Assembly replaced (280mm, 300w) - $55.39
155,997 11/25/2015 Transmission harness gaskets, transmission filter, transmission pan gasket, transmission fluid replaced - $292.68
155,912 - 11/24/2015 Magnaflow resonated 2.5 to 4 exhaust tips, Magnaflow Universal Mufflers 2.5 in/out - $640
154,9XX [8/4-11/14]/2016 Hood repair and paint, front left fender paint, front right door paint, rear right door paint, roof paint, left rear quarter panel repair and paint, right rear quarter panel repair and paint, rear bumper repaint - $2,755.82
154,9XX [8/4-11/14]/2016 Street Sauce Torque Converter, Rebuilt Transmission (0 miles on it), Aluminum Bufkin Pipe, Torque converter seal, Trans cooler o-rings, Valve cover gaskets, Chain Tensioner Gasket, Valve Cover plug, Half Round plug, Serpentine Belt - $3,712
OWNER #2:
Kevin Black purchased vehicle with intent to fix and sell; third owner (myself) paid for all work to be done by Kevin Black Enterprises (Lugtronic)
OWNER #1:
154,399 - 4/16/2015 - CEL Diag, Trans Internal Damage, ESTIMATE - $164.73
140,889 - 10/7/2013 - Tie Rods, Alignment, Vac Hoses - $1,297.50
135,479 - 7/1/2013 - Wheel Alignment, Coolant Pipe, Clean Plenum Drains - N/C
135,051 - 6/13/2013 - Timing Belt/WP/Thermo, Acc Belt, Trans Tailshaft Seal, Brake Fluid Flush, Fuel Filter,
Oil Change, AC Wiring Fix, Brake Hose - $5,342.71 (Done by Audi Dealer)
???,??? - 3/28/2013 - 1x Conti DWS 255/40ZR17 - $198.98
101,000?? - 4/30/2011 - 4x Continental DWS Tires 255/40ZR17 - $718.68
100,584 - 4/27/2011 - Struts, Shocks, Front Arms, Rear Arms, Alignment, Oil Change - $2,457.99
89,939 - 9/1/2010 - Oil Change, Charge A/C - $204.85
85,473 - 6/8/2010 - Brake Rotors/Pads F+R, Combi Valve, Vac Hose - $1,573.46
80,921 - 4/12/2010 - Remove Snow Tires - $32.21
79,076 - 3/10/2010 - Radiator, Bypass Pipe, G12 Coolant, Oil Change - $1,599.85
??,??? - 12/17/2009 - Brake Hose, Fluid Flush - $440.94
73,943 - 11/28/2009 - Change Snow Tires - $32.21
??,??? - 11/21/2009 - Replace N80 Evap Purge Valve - $261.30
??,??? - 9/30/2009 - Transmission Service, Front Rotors, Oil Change, B-Pillar Switches - $1,053.37
62,450 - 5/15/2009 - Oil Change - $102.96
58,948 - 11/18/2008 - Timing Belt/WP/Acc Belt Service, Upper Control Arms, Oil Change, Brake Fluid $2,783.03 (Done by Tyrolsport)
??,??? - 6/19/2008 - MAF(Warranty), Clean Airbox, Re-Install K&N Filter - N/C
??,??? - 5/30/2008 - MAF Sensor, Inspection - $552.71
51,752 - 4/3/2008 - Oil Change - $90.21
51,750 - 4/3/2008 - Goodyear Eagle F1 Tires 255/40ZR17 - $919.87
