Results 1 to 40 of 53
    Sep 17 2015
    long island
    034 dogbone mount review
    I recieved the "version 1" dogbone mount for my a3 today . Install was extremely simple and easy but removing the bolt was a bitch ! They tighten those things like crazy. The mount slide right in and I tightened it up as much as I could . I took the car for a spin around the block and what a difference ! There's not a single vibe in the car but all the rough shifting has been completely eliminated . Everything is as smooth as it should be from stock. Deffinetly recommend this to everyone !!
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    What's the torque spec of the bolt? Was it version 1 or version 2 you ordered?
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    Apr 11 2012
    torque spec was "tightened it up as much as I could", I'm not sure if that's a good idea, especially with something as finicky as the dsg. Mikey, you need to torque that to 100 Nm.
    8V Audi A3/S3 MQB Dogbone Mount Insert Install Guide
    Sep 17 2015
    long island
    I tighten it as much as I could , tomorrow I will go back and tighten to spec
    Apr 11 2012
    Quote Originally Posted by mikeyhandz View Post
    I tighten it as much as I could , tomorrow I will go back and tighten to spec.
    good man. make sure 100 Nm not 100 ft-lbs, I've mixed those up before when not paying attention
    Nov 02 2014
    2016 Audi Q3, 2015 Audi S3, 2015 Lexus RC F, 2015 GMC Yukon XL Denali, 2010 Camaro SS
    Quote Originally Posted by will13k7 View Post
    100Nm = 73.8 ft-lbs
    Established Member Two Rings hamz01's Avatar
    Aug 29 2014
    Chicago
    Any way to know whether to get Version 1 or 2 without looking under the car?
    Mar 30 2015
    Australia
    Quote Originally Posted by hamz01 View Post
    All S3's are version 1 I believe. I got under to check though. IIRC only golf's may be version 2.
    Ordered, just hope it makes as big a difference as people say
    Senior Member Two Rings FabianS's Avatar
    Jan 29 2015
    Calgary AB
    Anyone else have thoughts on this to share? Any confirmation on what type the 2015 S3 requires? I'm in Canada so I'd like to order and ship it once.
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    I've been reading up on these dogbone mounts and I can't seem to understand the advantages of these units vs what Audi installed at time of build.
    I mean should there not be some sort of play with the factory mount vs no play with an aftermarket mount - the vibration must be present for a reason, no?
    Do we have long term tests/reports on these mounts?
    Inquiring minds would like to know - :)
    Aug 29 2014
    Chicago
    Aug 29 2014
    Chicago
    Quote Originally Posted by FabianS View Post
    Only way to know for sure is to get under your car and take a look. Will only take a minute. I am hearing that the early S3s are version 1 and late 2015/2016s are version 2 but that's not confirmed.
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    Quote Originally Posted by bakedcorn View Post
    I was thinking this same thing...may be worth asking the guys at 034 either through their site or on the thread for this part.
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    Feb 03 2015
    In the past: 1993 100S, 2012 A4, More VWs then I can remember and a few Porsches as well.
    North New Jersey
    I just got one the other day. Should have it in the car some point next week, I'll follow up with that I find.
    Mar 30 2015
    Australia
    I installed mine this week and there is a noticeable difference in the 'tightness' of the car. Wish I'd done it sooner! No added vibes.
    Oct 03 2015
    Illinois
    I need to jump on this part.
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by JohnnyUtah787 View Post
    I have no experience with the audis but I have had plenty with Subaru, Honda accord's, and Honda civic's. if its anything like those, it will put more vibrations into the cabin of the car. it will be much more harsher. with no experience with the audi S3 cars, I don't know how much harsher it will be as that would be my question too. each car is different and each part is different, they all will do different things at different attachment points. on some of my past cars I changed out all of them and some just a couple.
    for sure this will make the car feel less of a soft/comfort car and allow you to feel more of what the engine is doing. as someone above said, yes there should be some play so keep the vibrations down but some owners want that feel back. how much this does bring to the cabin, only the ones with it on will be able to tell us.
    from the picture, it looks like it is reducing forward and back engine movement, which means it will not be so harsh, but I could be wrong.
    Aug 29 2014
    Chicago
    Quote Originally Posted by reyoasian View Post
    How long was the install?
    Did mine in 10 minutes, taking my time. I am still new to car work and being under the car made me a little nervous despite using two jack stands on either side of the car lol. Anywho, make sure you have a long breaker bar or cheater pipe to loosen the bolt. My breaker bar wasn't long enough but luckily the handle on my jack comes off and is hallow, allowing that to act as a cheater bar.
    Aug 29 2014
    Chicago
    Quote Originally Posted by 949 View Post
    It's not harsh at all. In fact, cabin vibration has increased zero. I would have been fine with increased vibration but there's none.
    Nov 13 2009
    the OC, SOCAL
    then its definitely a forward to backward mount. I assume when you accelerate its more engaged.
    when you jacked up your car, where was your jacking point?
    Sep 30 2014
    I had the 034 dogbone mount, and when properly torqued and installed it still showed a slight increase in noise and vibration - but only when under load. I reinstalled 4 times to verify it wasn't an issue with the placement, with no change. I didn't like the resulting vibration so I returned it.
    Nov 13 2009
    the OC, SOCAL
    what do you guys think about this item?
    http://www.uspmotorsports.com/Drivet...t-MK7-MQB.html
    Aug 06 2012
    san diego
    Quote Originally Posted by aj6 View Post
    that's all i needed to hear. ty
    btw i dont even know what vibration you guys are feeling/talking about in this car.
    what vibration is this supposed to eliminate? i dont even notice one AS IS
    figured this was one of those mods that people get just for the sake of making anything different
    Established Member Two Rings Benji00's Avatar
    Nov 26 2014
    Richmond, VA
    Quote Originally Posted by markn1689 View Post
    markn - I think the insert deletes some of the engine/tranny movement that robs the delivery of smoother power. This apparently does/or doesn't result in increased vibration/noise in the cabin.
    Aug 06 2012
    san diego
    Quote Originally Posted by Benji00 View Post
    how can it get any smoother? the dsg shifts so butter smooth allready. its seemless
    Nov 26 2014
    Richmond, VA
    I notice some clunking and hiccups at lower speeds....not sure if you have that? I assume the dogbone helps with that. I'll shutup and let people that have it do the talking ;)
    Apr 11 2012
    sometimes the 1st to 2nd gear shift can be rough, its still is with the insert, but there is less front to back movement when this happens with the insert.
    Aug 29 2014
    Chicago
    Just to make sure nothing got lost in translation: the mount does not aim to reduce vibration in the steering wheel as there is basically none stock. It's aim is to reduce movement of the engine under acceleration and tighten up shifting gears slightly, especially between first and second. Usually the cost is increased steering wheel vibration or cabin vibration but personally, I have not noticed any of that.
    Oct 03 2015
    Illinois
    I was wondering the same thing....seems super smooth to me as is. At worst a little clunking at low speeds/low rpm at odd shift points.
    Sep 17 2005
    Fremont, California
    Thank you for all of the interest and reviews! Feel free to PM me or send us an email if you have any questions or need help placing an order.
    - Laszlo
    MQB Audi A3/S3 Dogbone Mount Upgrade
    Jan 29 2015
    Calgary AB
    Laszlo, what variant would I need for a late build 2015 S3? Also, what would be shipping cost to Calgary, Alberta Canada T3G-4S9?
    Jan 29 2015
    Calgary AB
    I also have a friend with a Golf R, and he would like to order and combine shipping of the item with mine...
    Sep 17 2005
    Fremont, California
    All of the S3s we've seen so far have had the Version 1 mount, but I always recommend visually verifying. If you have a camera phone, you can slide it under the car and take a picture/video to check what mount you have. No ramps or jack needed!
    Our website can give you an exact estimate for shipping after you add the item to your cart. The cheapest option is DHL, which starts at ~$23. Due to the minimum shipping charge from the carriers and the small size of the part, it costs the same to ship one insert to Canada as it does to ship six inserts. If you have friends who are also interested, ordering together is a good way to save money on shipping.
    Looking for the same answer for Toronto, Canada (L4E 0V8)
    DHL delivery starts at ~$23 for your postal code as well. Please see my note above regarding minimum charges! Perhaps you have a few local enthusiasts you can order with together.
    We'd be happy to facilitate this for you if you place one order together!
    Jan 29 2015
    Calgary AB
    Is the Golf R variant the same as the S3?
    Sep 17 2005
    Fremont, California
    The Golf R can have Version 1 or Version 2 dogbone, so it's best to check.
    Jan 29 2015
    Calgary AB
    Gracias. I think I have 6 guys lined up to purchase. I'll get them all to verify which variant they need. Thanks for the help.
    Sep 17 2005
    Fremont, California
    Of course! Thank you for organizing this! Let us know what size t-shirt you wear in the "Comments" field during checkout and we'll throw in a freebie for you.
    Jan 29 2015
    Calgary AB
    Incoming order of 6 coming soon...
    Nov 13 2009
    the OC, SOCAL
    this is looking more interesting. I hope there is a sale on one soon.
    Jan 29 2015
    Calgary AB
    Had mine installed a week ago, and I really enjoy it. My DSG shifts much smoother I'm M mode and things just feel a bit tighter overall. It did add a tiny, tiny bit of vibration, but in a good way IMHO. Makes the car feel more like a machine like my Porsche 993. Great mod for the $!
