Results 1 to 40 of 41
    Dec 05 2015
    Atlanta, GA
    Broken motor mount question
    It's a long story, but I seem to have a broken motor mount on my B8 S4. It's on the right side and I was just wondering if anyone had any experience replacing a motor mount themselves (looks like a very long, difficult job) or experience with what it costs to repair. From the parts diagram it looks like it's maybe the inner part, but hard to get from a diagram. Let me know if anyone has any info (good or bad, but I'd prefer good).
    https://drive.google.com/file/d/0B0m...ew?usp=sharing
    Senior Member Two Rings UberBrute's Avatar
    Jan 05 2014
    E91 BMW 328xi 6MT
    Connecticut
    Check the 034 motorsports website for their mounts, they have a PDF install guide, that may help give you an idea.
    Sent from my Nexus 6 using Tapatalk
    SOLD 2013 Audi S4 | 6MT | Estoril Blue Crystal | Premium Plus | MMI Nav Plus | Sports Differential | Carbon Atlas Inlays | Alcantara inserts | 19" Peelers |
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    it's mind blowing to me that the mount upon which the motor sits is actually a liability. ive never heard of having to upgrade such a part but I guess leave it to the germans. maybe im being tough but with each speed bump i hit I know I'll be having to enlist 034 has well.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    How'd you break a motor mount?
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Mar 26 2010
    US
    Quote Originally Posted by rtl5009 View Post
    They are filled with fluid to dampen vibration. I think there is sensor that will flag an error in the ECU, when it fails. Failure is not uncommon, apparently - look at 034.
    https://store.034motorsport.com/moto...s5-q5-sq5.html
    Install: https://store.034motorsport.com/blog/installation-instructions-density-line-engine-mounts-b8-audi-a4s4-a5s5-q5sq5/
    2019 RS5 Sportback
    Apr 27 2015
    canada
    Quote Originally Posted by wwhan View Post
    interesting.. What do other cars use or do they use fluid as well?
    Apr 05 2014
    If you get a failure alert, but the mount is physically still intact, except for fluid loss...what are the issues? Does it affect daily drivability?
    2014 S4 Ibis White 6MT. Stealth Daily Commuter. Best Option = B&O
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by Thurston View Post
    My previous MazdaSpeed had the same issue. Stock mounts on the 2.3l Turbo there sucked too. I replaced mine with an aftermarket one right away even before I really drove it. In that case it really helped keep things stable and prevented the motor from twisting causing the dreaded 3rd gear miss/grind.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    It is not a "sensor" in the mount, it is an electric valve that the ECU controls, which alters the softness of the mount. At idle, the valve is open, and the oil can move thru the two chambers. Above idle, the valve is closed and the mount is stiffer because the oil can't move between the chambers. Lot of cars have these "dynamic" fluid mounts, and they are usually trouble.....Honda has these problems too.....
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    My motor mounts went, Audi quoted me like $1,300 or something like that. I bought 034 mounts, and my Audi tech friend took it to his Audi dealership up north and did it after hours for $300.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Apr 27 2015
    canada
    Quote Originally Posted by schirm View Post
    pricey! Can i ask - would they not cover you because of your tune or were you out of warranty?
    Apr 23 2009
    Forked River nj
    Out of warranty.
    Past
    Jun 05 2015
    Houston
    my dealership denied warranty because i was "lowered" on OE sport springs. ended up getting 034 mounts and took it to an independent dealer. those fluid filled mounts are garbage
    Deval Front Lip - Roc-Euro Intake - AWE Exhaust w/ Resonated Downpipes - H&R OE Sport Springs - Eurocode USS Sway Bars & Endlinks - Eurocode Alu Kreuz - 034 Drivetrain/Transmission Mount Inserts - 034 Density Line Motor Mounts
    Nov 10 2014
    Apex, NC
    i've done it on a couple cars.. never an audi.. but it was fairly simple .. jack the motor up.. replace the mount.. depending on how tricky the location is..
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Apr 27 2015
    canada
    Quote Originally Posted by pnguy37 View Post
    cold hearted on there part.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    ^Replaced mine in the 2.0 but the 034 Street Density Mounts are a welcome change.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by mm5300 View Post
    From my assessment being under the car on my lift many times and observing the mount locations, you would have to support the engine from above and drop the subframe to access them. I'll most likely be upgrading mine to the 034 mounts sometime in the next year. Mine aren't broken as far as I know but I want the mounts to be durable for launches.
    Looking at the first pic, WOW. You broke the actual aluminum mount housing, not the rubber part. How the heck did you do that?
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    wow were you in an accident before? that is the only time i have seen the alum mount break.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    I've gotten quoted $689 from the dealership for engine mounts replacement.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by MrFunk View Post
    I assume that's only labor, correct?
    Aug 27 2008
    Houston Area
    Quote Originally Posted by Vogz View Post
    This isn't the "engine mount" - it's a "mount support" based on the part # visible in the OP images - Part #7 at : http://genuineaudiparts.com/parts/20...agramCallOut=7 The mounts are #1 and #2...
    I'd like to know how this was broken as well - OP - I'd look for other damage...
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by B8_Jim View Post
    Tomato toMAto. It's connected to the mount, it's metal and he broke it. That's the concern here. Not the terminology I used for a metal part that connects the mount to the subframe.
    Oct 09 2008
    Maybe not a concern for you. But it is a concern for the guy trying to order the correct part to fix his car.
    The Awesome™
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by JoshDub View Post
    I wasn't telling the OP which part to order.
    Apr 17 2004
    Socal
    I'm pretty sure the B8 S4 mounts do not adjust their firmness like some of the fluid filled mercedes mounts. The S4 has fluid that when released results in the sensor tripping to let you know the mount has failed.
    Sep 24 2014
    Central NJ
    No, not a "sensor", the mounts have an electric valve in them that changes the fluid path, to change the firmness. The ECU has no idea when the mounts break and leak fluid out. The ECU does set a DTC if the valve electrical circuit is open or shorted.
    Senior Member Two Rings rockstar143's Avatar
    Oct 01 2013
    United States
    so basically magnetic ride control for the motor mounts
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    Old thread but if it helps somebody....
    I replaced mine in about 4 hours.
    Car in a quick jack
    Engine support bar from harbor freight hooked to the rear lifting points on the SC
    Unbolted the trans mount (I’m manual)
    Was able to lift the engine enough to get the mounts and brackets out on each side with a little finesse. You will need to remove the oil cooler on the driver side to access the mount.
    I did not touch the sub frame (there is one subframe bolt on the driver side that has to come out to access the rear mount bolt, FYI)
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Quote Originally Posted by B7TitaniumA4 View Post
    Car in a quick jack
    This is the info I’ve been hunting for after finding a puddle under my passenger side this morning and figuring out it’s the engine mount.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Feb 16 2019
    miami, fl
    man that's nothing, there's a guy on here the the broken mount broke a hole in his crank case, cost him an engine.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Sorry I can't provide you the specific info. you are requesting but it is a known failure point. I had one of mine replaced under warranty but it's leaking again with 87K total miles on the car. Go with 034's mounts. I just had the mounts replaced last week on our 2007 A4 with 034 street density mounts at Komet Motorsports in Chicagoland (St. Charles) for half the price of either of the two quotes locally.
    It was worth the 2.5 hr. drive. This is the 2nd car or ours they have worked on, and I would make the trip again. They are excellent, are Euro car experts, and work on high end vehicles, including vintage muscle cars. Can't say enough great things about them -- honest and reasonable. So far, everything I have even asked them about, they have seen, repaired, and/or upgraded.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Oct 23 2014
    _
    Is unbolting there trans mount necessary for 6MT cars?
    I ask because I’m having a little bit of trouble getting the right side out of the space after unbolting everything and I’m certain I’m past 20mm as 034 states in their guide.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Mar 26 2016
    I did and it helped to get the engine to “pivot” enough to work it out. I used the engine bar technique, I did not drop the subframe at all.
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    I just did this on my DSG, and did what I saw suggested on the ECS tuning guide. That was to lower the steering rack, which gives you space to drop the mount through.
    I also did use the engine support bar, and did raise the engine quite a bit to have more clearance.
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Oct 23 2014
    _
    Thanks guys!
    I got the passenger side out with a little more finesse than I was using initially. It’s safe to say the passenger side failed based on the image below.
    I moved over to the driver side, but stopped for today once I got to the oil cooler. I was working on the last hidden T30 toward the cabin and started getting oil drips. I expect some oil to drip out but can you guys tell me how much to expect here?
    With the oil cooler and the AC condenser to remove, I decided to just finish it up tomorrow with the temps dropping.
    EDIT: I’m just seeing the ECS procedure, but I’m curious if I could finish up the driver side without removing the oil cooler, but also not removing the front sway and steering rack.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Mar 26 2016
    Wow that’s F***ed
    Some oil will come out, I don’t remember it being “a lot” did you get a new seal for the cooler?
    see if you can avoid removing the coolant lines tho… i drained mine cause I was pulling supercharger and stuff at the same time I did my mounts.
    You don’t need to pull the compressor iirc.
    Oct 23 2014
    _
    I do not have a new gasket for the oil cooler, but could order one being that I need to order a new pan for my B5 S4 anyway. I was more concerned that I’d need to get a full oil change kit while I’m ordering more parts.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by bakedziti View Post
    Thanks guys!
    You're not removing the rack entirely, you're simply lowering it. Get some wire hangers or something to hold it in place. The swaybar is a piece of cake to remove as-well, and since you're down there, it's a no brainer to make life easier.
    I don't want to say its impossible, but unless you drop the subframe or lower the rack, or even start messing with lines and coolers and whatnot, I think it might be close to, if not, impossible to remove the engine mount. There is just not enough space even when raising the engine up to get to the 2 bolts that hold that "shied" in place.
    Honestly, besides my engine support bar twisting and scaring the shit out of me while holding the weight of the entire engine, I had a MUCH easier time with the drivers side than I did with the passenger, with the rack lowered, & swaybar out, it basically came right out. No oil lines or anything else to worry about and in reality, its 8 more bolts. You're really removing (2 bolts on bottom of end-links, 2 that hold the rack, and 4 for the swaybar mount). Obviously disconnect the rack wiring, but no need to touch anything else.
    Oct 23 2014
    _
    The sway bar route requires an alignment which for me with ACC is much more involved and expensive than a typical alignment. Not to mention the xbrace and sway bar end links are all TTY bolts that need to be replaced with each use.
    If the oil cooler is really only going to spill a few ounces of oil, then I think I’ll continue that way today and try to pick up a new gasket for the cooler locally or order one online.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jul 27 2007
    Orange County, NY
    You don't need an alignment after a sway bar removal, you must be thinking subframe...and I've reused tty bolts. Just make sure you check them. Your choice in the end.
