Results 1 to 7 of 7
    Feb 22 2009
    Ottawa
    Windshield wiper rests too high on passenger side
    I noticed that the passenger side windshield wiper rests a bit too high. When the rain sensing wipers are on and in the down position, I can actually see the passenger side wiper going about an inch up the windshield. When the wipers are completely off it's slower but I can tell it rests about an inch higher than the driver side. I can manually push it down to where it should be.
    Is this something WD40 or a wrench can fix?
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Post pics. If the one wiper is going up to far as well, you would probably need to remove the wiper to align it properly.
    Aug 06 2012
    Parker, CO
    Yes... you can pop the arm off and make the adjustment. I had to do that on one of the new windshield installs I had done on my allroad. Actually..... made the glass shop do it.
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Feb 22 2009
    Ottawa
    Quote Originally Posted by B-Time View Post
    Here's how it looks when they're off:
    When they're on:
    So is it as simple as loosening this bolt, rotating the wiper down a bit and tightening it again?
    Aug 06 2012
    Parker, CO
    No, you'll have to remove it completely as there are grooved teeth holding it in place.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    And be carefull when you do this....the spring in the arm is stronger than you think....you can crack the windshield if things go wrong....don't ask me how I know....new blade = $16, new windshield = $600.......
    Feb 22 2009
    Ottawa
    Quote Originally Posted by treginginco View Post
    So remove it, and then rotate counter-clockwise by one tooth and put it back in, then tighten?
    I got my windshield replaced a couple of months ago, it might have been like that since but I can't be sure since I think I would have noticed it before.
    What spring are we talking about? If I loosen that bolt is something going to fly out at me?
