Results 1 to 4 of 4
    Jul 03 2013
    new hampshire
    Camshaft adjuster seals ?s
    Anyone know we're you can buy these seals cheaper or if there is a alternative thing you can use i.e. o-ring or something. I found them on ecstuning site. But didn't know if maybe you guys have found a different type of seal that would work, or should I just stick to the original type. Thanks
    https://www.ecstuning.com/ES2726697/?gclid=CNG0sa_z4skCFYcWHwod5HQDOQ
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Cheapest I found are from the link below. I always buy my OEM parts from this place.
    $46.13
    http://genuineaudiparts.com/parts/in...&siteid=214407
    Mar 24 2013
    Oakdale, CT
    I don't think there is any alternative. Be careful when installing them also. Start from the rear obviously and work your way out.
    -Adam
    Jul 03 2013
    new hampshire
    Ok thanks for the tip, and the link
