Results 1 to 15 of 15
    Jan 30 2011
    Home
    Stage 3 apr upgrades?
    Has anyone taken their basic stage 3 apr setup and improved the supporting mods? (injectors, fuel pump, etc)
    Basically thinking about going to an EV injector setup and a re-tune. Has anyone done this and if so what kind of improvements have you seen?
    TIA
    It's stuff like this that makes owning an s4 exciting. Beating high hp super cars with your old German grocery-getter; Long live the s4! - AudiMode
    01.5 Silvaro S4 Avant DD
    01 Laser red sedan Stage3 SOLD
    99.5 a4 1.8t apr stage 3 SOLD
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Not much point to it. If you want more power, you will have to upgrade the turbo. Adding more fuel to the same amount of air will not do anything. However, you could have it tuned for e85, which would be a good increase in power. Or you could run meth.
    But you have lots of t25 options as well, from a couple gt28's to gt3071r, or even an EFR. If you are looking for more power, that's what I would do. the turbo used on apr stage 3 is kind of small. It is a great kit, but not really for developing huge power.
    With all of this said, you need to keep it within your stock rod limits, assuming you have stock rods.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    edit : like redline said
    This is All the people that have a GT2860 or 71r that are not runing APR tuning is pretty much what you will end up with. With the ARP turbo and mani setup you will be closer to the GT2860 power level vs the 71r.
    the key will be the retune as APR tunes on the "safe" side, less aggressive. so for $800 you get 20 more HP? $250 for EV550 and $550 for new tune give or take?
    SOLD the GOINHAM A4 ---> GT2860 Project
    Jan 30 2011
    Home
    Ok, what if I was looking for smoother idle, better fuel efficiency. I am just wondering if my setup that is 10 years old is outdated and inefficient. As for power I am pretty happy with what I am. I do have stock rods so I am not looking push the envelop on that.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Sean4 View Post
    It is most likely maintenance issues, not issues with the APR kit.
    2000 S4- Working?
    Jan 30 2011
    Home
    I have fresh plugs in the car, I will clean the air filter and the Maf and go from there
    May 17 2014
    Raleigh, NC
    I would toss in some genesis g2 630s. or some double foggers. thats if you end up doing it. The better spray / atomization will net more low end power and a more efficient burn. Will it be a night and day difference, but im sure you'll notice a gain or improvement.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    What injectors does yours use, 440s? Ive been very happy with my genesis 415s, for idle and such. If you change to anything larger, your going to need a new tune. But you can run 415 at 3.5bar, and keep the same tune, assuming you have 440s
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Nov 17 2011
    Fredneck Maryland
    The 440 and 415 are good but an older injector. I have the boschEv550 idle is like stock
    Sent from my SM-T560NU using Tapatalk
    Dec 23 2009
    Boulder, CO
    But the 415 won't require a new tune, 550s will
    Established Member Two Rings chaoticdopey's Avatar
    Sep 08 2015
    North Hollywood , Ca
    sorry for thread jacking but if i was to put a gt28 on my car with the stage 2 kompressd tune would i have to upgrade anything being its pushing 22lbs?
    2001 Audi A4 1.8t
    Catless DP
    Full 3'" Custom Exhaust
    XS-Power Tubular Manifold
    Kompresssed STG 2 Tune
    Stock k03s Turbo
    Dec 05 2007
    Yeah, your block once you put a hole in it.
    OP, as far as I know APR injectors are the same injectors as ones already out there with an APR sticker on it. Nothing would need to he changed if you were to throw in Bosch EV injectors other than wiring modification if necessary. Find out what flow rate your current injectors are then get them in the EV. If what you want is a snoother ride, that with decent ignition spark mod shoukd do it..
    Apr 22 2007
    Riverbank, Ca
    I ran my boost up a couple times over 20psi and I ran a really big turbo on wastegate pressure for a long tjme on the apr tune.
    I had thought of using a fuel map adjuster like one APEXI makes but ended up never doing it. I was going to throw 660s on it and adjust everything down appropriately as a basemap. Again, never did it but the theory is still there...
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    May 17 2014
    Raleigh, NC
    if you are gonna retune EV-14 550s or Genesis G2 630s... and in that case, just get the 630s.
    The injectors will be happier and have more headroom for growth later down the line. once youturn up boost and need more fuel in there.
    Dec 05 2007
    Quote Originally Posted by andyrew View Post
    It has to due with air to fuel ratio. What boost was the wg pressure on with the larger turbo? Do you know what your af ratio was during spool and at wot? If you don't have enough fuel to compensate with air then you run lean. That is what blows the motor. If the fuel was able to keep up with the air at wg pressure, then things will be ok. And the ecu can adjust slightly (something like up to 15% or so, so I read somewhere). This is why you can run different sized gt28 turbos on the same ots tune.
