Results 1 to 31 of 31
    Jul 16 2015
    Scarborough, Me. NorthEast.
    Gearbox malfunction, limited use?
    Ok my question is what does this mean?
    This past Saturday my son and I were doing a couple errands and I had this go off about 8 times. Popped up on the cluster and went away. It didn't do it again till yesterday on my way home. It did it about 5 times.
    I'm getting my 35k mile service done tomorrow, so part of that will be the DSG fluid and filter change. Anything I should know to tell the dealer. The car still seems to drive normal, shift normal so I'm not really sure what is up.
    Any suggestions?
    Thanks, Bill
    2012 S4 DSG, Phantom Black............................................. ...........................
    mods; StaSiS WC Sport Exhaust, gmg downpipes, StaSiS Challenge Suspension Kit, gmg WC Swaybar KIT front and rear, Adjustable front control arms, StaSiS 390-32mm mono6 BBK
    Revo Supercharger pulley, APR Coolant Performance System, Roc Euro intake, Revo Stage 1+, FORGELINE SC1 19x9 wrapped in Michelin PSS 255/35/19's
    1/[email protected]/[email protected]
    More to come, work in progress.
    Active Member Two Rings IngolstadtTech's Avatar
    Nov 05 2015
    1986 Ford Mustang Lx Notch
    Massachusetts
    Im not totally sure, but there may be a tsb with an svm update for this. Just describe the symptoms to your service advisor and they should take care of it.
    Jul 16 2015
    Quote Originally Posted by IngolstadtTech View Post
    Great, thanks for the advice, I will let him know tonight when I drop it off after work.
    Bill
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    I just had this happen a few months back. There's a sensor in the PRND shift selector that went bad and needed to be replaced. Its accessed from under the car so they should not be digging through your interior. Good new is that it stores a code so they should be able to find exactly whats wrong.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Isn't this usually the first sign that the mechatronics unit is going bad?
    Jul 12 2012
    Initially that was my thought because I was told that clearing the codes should resolve the issue. After clearing and readapting the sensors the problem returned. At that point they replaced the sensor and it has not returned. In my case I had noticed a few time before that when I would put the car in park and turned it off if I opened the door or tried restarting the car I would get prompted to put the car in Park - at which point I needed to shove the lever so that the sensor closed the circuit.
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by jsh139 View Post
    ya this sounds exactly like the mech unit is going, same symptoms I had. Hopefully your not TD1'd, otherwise they won't fix it for you under TSB.
    http://www.audizine.com/forum/showth...-tronic-(DL501
    From your mods, if that off chance you are, this worked great! Don't really notice how broken it is since it's so slowly digressing.
    https://www.ecstuning.com/Audi-B8_S4...ion/ES2697203/
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Senior Member Three Rings Moto One's Avatar
    Mar 26 2010
    C5 Z06 (going on 17 years)
    Tahoe/Truckee
    Ours just did this after our 75k (with DSG service) and it was in the shop for three weeks, a temp sensor (that needs the trans disassembled all the way) to replace the part. Hope your are under warranty.
    Mark
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    What year is your dsg?
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Established Member Two Rings S-FIZZOR's Avatar
    Apr 19 2010
    2010 S4, 2007 Audi A3
    San Francisco / Elk Grove, CA
    Possible failing Mech unit or speed range sensor. Leaning more towards the speed range sensor.
    H&R Sport Springs |Stratmosphere intake | Hoen endurance yellow fogs | Vag'd |ECS Tuning led license plate lights | Hardwired 9500ix | Supercharged Badges| 19" Rotiform MIA Gunmetal
    Jan 16 2013
    I'm guessing it's the mech unit. The same exact thing happened to me and the dealer swapped the unit. After the swap I didn't see the issue for about a year until it popped up again 2 months ago. The dealer went ahead and replaced entire DSG tranny for me after that :D...they had my car for a month!
    Jul 16 2015
    My car is a 2012, when I dropped it off at the dealer tonight the service advisor said they would do the 35k mile service and look into the issue. He told me if it was determined to be a issue from abuse that it wouldn't be covered. He also asked me if my car was ( chipped ) I said no. I know I answered him falsely just because he used the wrong term. Chipped, no... I didn't tell him that it had a ( tune ) I did put the stock tune back in it yesterday. So right now it's not tuned. And it was never chipped.. Do people even replace chips in the ECM'S anymore?
    So did I lie to him, not really because he asked the wrong question. Will he be able to tell, probably so he will most likely void my warranty and Audi care.
    I'll most likely find out something tomorrow.
    Bill
    Jul 16 2015
    Ok, I picked my car back up at the dealer last night from having the 35k mile service done.
    I had them look into the gearbox malfunction light, code that I have had coming on a few times now.
    First they completed the 35k mile sevice under my Audi care, no charge.
    Second, they started scaning the car to see what was up with the fault light coming on. They stopped diagnosis after about a half hour as the technician noted Extensive after market modifications.
    What the notes say on my paperwork are Performed scan tool operation and found faults for Excessive clutch temperature inside transmission. Faults appear to be Sporadic.
    So as of now he said my car is not TD1 but he would involve Audi if I wanted to try to have them go further and have them make the call as far as it being under warranty or not.
    So I just took it back and and paid the half hour labor out of pocket to avoid my car from being TD1. We will see how it acts and go from there.
    Bill
    Jun 05 2015
    Manchester
    I had the same error code come up on mine - well the same error code description. It is a known issue apparently and requires the circuit board to be fixed on the mech unit. Audi sell replacement / fix kits for it.
    Mar 26 2010
    Tahoe/Truckee
    Quote Originally Posted by Jv218 View Post
    2011. I was told that there was a TSB for this, if and or when it happens.
    Mark
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    Quote Originally Posted by Moto One View Post
    Mark
    There's a vin checker you can use on audi website
    Jul 16 2015
    Quote Originally Posted by Thurston View Post
    If the car is under warranty and you don't have an ecu / dsg tune you make them pay for every single g.d. penny. period. the service rep has you by the balls with this td1 bullshit because you are letting him - my friend, audi will fix your car but you are going to have to get a little uncivilized. Looking at your mod list you have nothing to worry about. I think the service guy probably knows you are already extremely fearful of td1 and is trying to work w/ you or maybe not but brother Audi will fix your dsg.
    When they plugged into my car they said they notice it was tuned and that I tried to remove it.
    they also said that they noticed I had a smaller supercharger pulley.
    So that alone he said they could TD1 my car. He also told me that I had a part on the back of the supercharger that didn't allow for the boost pressure to bleed off like it was designed to.
    I said (what pert are you talking about?) He pulled the rear plastic cover off and pointed to my ECS boost tap.
    I told him that it was a boost tap so I could see actual boost pressure on my p3cars boost gauge.
    He said the technician said that it holds something open to increase the boost pressure.
    I told him his technician was wrong. Its just so I can see actual boost and not requested boost.
    He then said if I wanted to make a stink about them not going further into the problem that they, the dealer would get Audi involved and let them make the call if its warranty or voided.
    Maybe there is another Audi dealer in New England that is mod friendly that I could go to?
    I'm going to be working with a top tuner very soon that has shown interest in doing a nitrous tune for my car. I just need to make sure my car is good before putting more power to it.
    Bill
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Quote Originally Posted by hdmlnium1 View Post
    Bill
    ahh gotcha well that makes more sense - very interesting. I don't think that ecs boost tap talk is fair at all but the rest makes sense. I'd say none of the dealers are "mod friendly" but i'm sure some are, i've never found em. I'd roll the dice at this point and see what AoA says. I'm sure they can prove the ecu tune requested to much hp / tq for the tranny but who knows.
    Mar 02 2009
    State of Confusion
    You have a Revo tune so you need to go to the Revo dealer to have it flashed back to true stock before you go to any ANY Audi dealer. Your SPS will only take it to a stock-like level of performance but they can still see that it is flashed.
    Mar 02 2009
    State of Confusion
    If you have one of the early Revo supercharger pulleys that is silver then newspaper and tape the area off and spray some black plastidip or black paint on it so you can smile and say "no it's factory..."
    Apr 27 2015
    canada
    I don't know how I missed that your ecu was tuned - yeah do what mjfloyd1 is suggesting
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    I modded my car and Audi is giving me a hard time about trying to scam warranty work, shocking.
    Jul 16 2015
    Quote Originally Posted by o1turbo30v View Post
    Actually I bought my car already modded. When I bought it down in Virginia I was told that all the work done to the car was done at a authorized Audi shop and it still had a full warranty with audi care.
    Yes I've done a few things to the car since then but mostly cosmetics.
    So am I trying to scam warranty work? No, not at all. I was told by the Dealership that I bought the car from that warranty was still all good.
    As far as the pulley it is black, so maybe they measured it.
    Bill
    Mar 02 2009
    State of Confusion
    It probably hadn't had any service or warranty work done after it was Revo flashed so it hadn't yet been TD1 labeled. It also took Audi a while to crack down on ECU flashes so who knows.
    Definitely take it to a Revo dealer and have it flashed back to true stock.
    Remove the boost tap just to save yourself any headache.
    Oct 30 2006
    B8 A4 Avant 6spd
    Bill
    If your car is flashed and has a pulley on it, then you will receive a TD1 code the moment your car is scanned. If you want your gearbox malfunction problem diagnosed, you will have to remove the pulley and flash. As far as the boost tap, you landed on a tech thats a fucking clown. Probably an old timer that doesn't know what they're looking at. There is a harness that fails intermittently in the transmission, the whole transmission has to be split apart and disassembled to replace it, so if it is that problem I suggest you make your car a bit more stock and get it taken care of.
    -18 718 GTS
    Jul 16 2015
    With everyones knowledge here, is there any chance that this issue will not come back because of the fluid and filter change that was just done to the DSG?
    I thought I read somewhere while searching about the issue that sometimes it was contributed to dirty fluid or a clogging filter. I know the dealership just changed all that and the fault code, light has only come on 2 different days. Maybe caught it in time, or no such luck?
    Bill
    Jun 05 2015
    Manchester
    Bill
    Due to it being any number of possible problems it is hard to say. Only way to know is drive it and see.
    Jul 16 2015
    Well a little update. The fault, light, message came up again yesterday about 4 times in about 3 minutes. Then nothing after that.
    I guess I will have to call the dealership down in Virginia where I bought this car.
    From the receipts they gave me all this work was done when the car was new.
    I looked at the service history on carfax and it was serviced at Audi a few time after the mods were done to the car.
    It had the Thermostat changed and other things done to it under warranty just before I bought it.
    Why no issue then about warranty?
    I'm actually on the fence about just trading it in and getting something different.
    On the fence I say because I really like the car but I don't want to deal with the issues when I was told from the dealership that I bought my car from that everything that was done to the car was performed at an authorized Audi shop and that it was still under factory warranty and had Audicare.
    I don't have the cash available to have the transmission fixed out of pocket.
    So I guess Trading it in and moving on may be my best bet.
    But, I really enjoy this car and it pisses me off that I was lied to in Virginia.
    I'm lost in thought right now.
    Bill
    Jun 05 2015
    Manchester
    If you dealer said it was all good under warranty take it back to them....
    Jul 16 2015
    Quote Originally Posted by sebgreen View Post
    I'm going to give them a call and see what if anything can be done.
    They were asking 45k for it, I ended up getting it for 40k
    I paid that much only because of the amount of money that was spent on the mods and for them reassuring me that it was still under full warranty with all that done.
    I really don't want to get rid of it, so I will see what they will do.
    Thanks, Bill
    Jun 05 2015
    Manchester
    If they said it was still under warranty then they either lied or could it be a non Audi warranty?
    Did you get anything on writing?
