Results 1 to 18 of 18
    Dec 09 2007
    2012 A7 / 2007 RS4 Misano Red
    North Bergen
    Replacing stock front rotors for S7 / What to replace with?
    Looking to replace the stock front rotors. I am getting a bit of vibration when braking at high speeds.
    Should i just go with stock OEM rotors?
    Also thinking about going with EBC red stuff for the pads.
    I had used another brand, but am not happy with breaking capacity of the pads.
    2013 Audi S7 Estoril Blue 2.0
    2016 Porsche Macan Jet Black
    2012 Audi A7 Moonlight Blue
    2007 Audi RS4 Misano Red
    2010 Audi TTS Misano Red
    2008 BMW M5 Sapphire Black
    2009 MB C63 Alpine White
    2000 Audi B5 S4 Laser Red
    Veteran Member Three Rings yakev724's Avatar
    Jun 26 2014
    Brooklyn
    I have absolutely no idea but I am quite fond of your car history. Top choices all around!
    Dec 09 2007
    North Bergen
    Thanks! Anyone else can chime in?
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    So far as I know, the only aftermarket option is from Adam's Rotors
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Dec 09 2007
    North Bergen
    Are people going aftermarket like Adams or just oem?
    Senior Member Three Rings mik34's Avatar
    Feb 04 2010
    Manitowoc, WI
    I have Adams but only because I wanted drilled rotors for the look. I've had them for well over a year with no issues.
    Sold: 2013 : Ice Silver, Carbon inlays, APR tuned, 21x10 HRE S101, AWE exhaust, Carbon fiber mirrors from RS6, Drilled rotors, H&R lowering module, Escort 9500ci, Ceramic brake pads, Deval carbon fiber rear diffuser, Xpel Ultimate, Opticoat
    Sold: 2009
    Whoever said money can't buy happiness...doesn't own a (tuned) S6.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    For myself, it's hard to think of much better than stock considering they are aluminum hat with pins. You'd have to find two piece high quality set otherwise it will likely be a step down from OE.
    Here's a cutaway of what the S6/S7 front rotors look like.
    http://www.audi-technology-portal.de...nload?file=844
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Three Rings Kem's Avatar
    Aug 30 2004
    Colfax, CA
    I was hoping to convince JHM to do a lightweight 2pc rotor for our cars. Their B8 S4 rotors save 14.5lbs, I could only imagine with our massive 400mm rotors the weight savings would be.
    2005 6MT ur-Allroad
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Kem View Post
    FWIW the stock S4 rotors are all steel. Stock S6 rotors already have an aluminum hat so really any weight savings over stock is only going to come from reducing the mass of the steel ring which may not be beneficial when it comes to longevity for repeated stopping power. Might be why there aren't really any options currently since there is almost no benefit. One could argue someone could use a better steel metallurgy or offer a two piece with a better price point for replaceable rings but that may be limited.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Jan 05 2010
    Edmonton, AB
    Quote Originally Posted by gk1 View Post
    Absolutely correct.
    Quote Originally Posted by cheezItt View Post
    The OEM rotors, as mentioned, are pretty trick. If you're getting vibration, it's likely not "warped" rotors, but rather an issue with poor pad deposition (i.e. high spots of pad material transferred to the rotor). Either get the rotors turned (if they have enough meat remaining) or new ones, then be careful if you've been using the brakes hard. Don't apply the parking brake when the brakes are hot and also don't keep the brakes applied in the same circumstances. Both will transfer a layer of pad material in the shape of your brake pads and then reveal itself as vibration under hard braking.
    2013 Audi S6
    2016 Porsche GT4
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    I'm awaiting delivery of my Adam's...got them close to OEM pricing for all four, and curious if the slotted benefit will be noticeable.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by S4Per View Post
    Please do a weight comparison stock vs. Adams. I'm sure we'd all be interested. Thanks.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Veteran Member Three Rings redrocker55's Avatar
    Feb 21 2010
    St Louis, MO (USA)
    Another cause of warped rotors is improper installation of the lug bolts. They need to be properly torqued and in the correct order.
    Dealership and Indy shops love to use air tools to tighten lugs and this is not a great way to get a proper torque setting. They need to be manually tightened.
    2016 S6 Prestige, Misano Red Pearl, Driver Assist, B and O, Sport Pkg, Carbon Atlas, Black Headliner,
    Alu Kreuz, 034 Motor Sport DSG Insert, RS7 Intake Box, APR Stage 1 w/ Dongle
    Sold 2010 S4 Brilliant Red DSG with Prestige Pkg
    Sold 2008 VW GTI DSG
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by redrocker55 View Post
    This +1.
    Had a place tighten the lugs with only what I could assume is a 1000 ft-lb air gun. I had to use a 4 foot piece of pipe to sleeve a 2 foot breaker bar just to budge them. Never went back there again.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Feb 17 2004
    2013 Audi S6
    Will do.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Senior Member Three Rings AudIan's Avatar
    Mar 01 2014
    NC USA
    Brake rotors don't warp.
    2014 Black S6 LEDs black wood and aluminum inlay, black optics
    Senior Member Two Rings goliath1's Avatar
    Apr 13 2014
    custom built softail
    RI
    Quote Originally Posted by mik34 View Post
    Drilled? I ordered mine drilled and they said the vane positions wouldn't support cross thru drilling. so I am getting dimpled. It doesn't help the braking, I just like the look.
    Feb 04 2010
    Manitowoc, WI
    Quote Originally Posted by goliath1 View Post
    I did get drilled. The drilling is OK but the pattern is backwards on one side of the car because they couldn't drill them in the reverse pattern (vane positions I guess). You can't tell because you can't see both sides of the car at the same time but I still went with drilled instead of dimpled (probably would get dimpled if I had to do it over).
    Sold: 2009
