Results 1 to 9 of 9
    Active Member Two Rings delanobailey99's Avatar
    Nov 21 2015
    herkimer ny
    2006 A4 2.0 engine noise
    Please HELLLPP!!!!
    Help with my 2006 A4 2.0 engine noise.
    Dec 19 2015
    Mount Vernon, NY
    When you find the answer please let me know I'm having the same problem, I went to autozone it's saying to replace the camshaft adjuster solenoid but I'm also getting codes for a turbo under boost
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    Deffintley post if you get this fixed, I have the exact same noise but no engine codes or anything. I have had it for some time now and decided I need to wait till something breaks or I get a cel.
    I'm new to Audis but I thought these engines just sound like that. Like Hondas always had this ticking noise. Are you getting any codes?
    2008 A4 Avant 2.0T SE JHM Stage 1 / 19x9 S5 Peelers / ST Coilovers / Hyperco Rear Springs / RS4 RSB / APR Carbonio intake / 034 HFC/ Custom DP/ S4 OEM Dual exhaust / 20% tint / LED tail lights / Premium White LED interior lights / FourRings puddle lights / 5.1 Android HU
    Not installed: S204 Lip / CSR skirts / S4 Rear valance / CX FMIC / RS6 Grille / Modified center console
    IG: @garage1203
    Nov 07 2015
    Pennsylvania
    Quote Originally Posted by mdot1203 View Post
    I don't have any. Had a friend ride it in and he said he thought it was normal noise, so who knows I'll post when something breaks :)
    2006 A4 6MT - JHM Stage 2 93 Oct flash | Cam Follower Conversion | JHM HFC | JHM Downpipe | B6 S4 Exhaust | JHM HPFP Internals | JHM Small Core FMIC | 034 RSB | Sway Bar Endlinks
    Oct 01 2014
    kent, uk
    If it helps mine sounds similar to that, i believe its something to do with the direct injection because they sound like a diesel on tickover!
    Although mine doesnt have that metal sound, but not sure if thats the grips youve got resting on the engine.if not, may be worth getting it checked.
    Nov 07 2015
    Pennsylvania
    I'm new to German cars, but I don't think it's the direct injection ticking noise. What we are hearing and questioning about is that metal noise, almost like a bolt on a heat shield rattling noise. I however noticed on idle mine is pretty rythmic. About a second or two of the noise, then a second or two of it being silent. And repeat.
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    saw a video on youtube of a b7 with the same loud noise and everyone said it was because of the cam tensioner for engines with high miles. however, i have 188k on my b7 and don't have anywhere near this loud of an engine. post back I'm interested if you find antything out
    Jun 28 2015
    2018 Atlas
    Bend, OR
