Results 1 to 15 of 15
    Veteran Member Four Rings teutonic_blur's Avatar
    Puerto Rico
    Paging David Sarabi or any other Revo Geek...
    I recently had a coilpack failure. When I hooked up my vag-com it would not achieve communication with the ECU. After trying several times and failing, I tried with Lemminwinks and it worked fine. After that, vag-com worked.
    Same thing happened a second time, no vag-com, try Lemminwinks, it works, try vag-com again, it works.
    After swapping the coil pack I took my car to the dealer so they could document the DTC. The rep came to me and asked me if the car was chipped. I said "no, why?" and he said that they could not get their computer to talk to the ECU...
    So, the Q is: could this situation be related to my Revo flash?
    If A is a success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut.
    Albert Einstein
    It's not that I'm afraid to die, I just don't want to be there when it happens.
    Woody Allen
    2003 A4 1.8T FWD 5M
    Revo SPS1, K&N drop-in, NGK Coppers
    Puerto Rico
    Less than 5 minutes after I posted this I got a PM from David telling me to call him.
    We talked about the issue and he said he was going to send a new version of the flash to my local tuner so I can get a re-flash.
    This guy is truly amazing.
    Albert Einstein
    Woody Allen
    2003 A4 1.8T FWD 5M
    Veteran Member Four Rings A4 - Oh Snap's Avatar
    May 03 2004
    Irvine, CA
    i have revo and i can communicate with the ecu w/ no problems. has this issue always been the case or is this a recent issue?
    Puerto Rico
    I've always had some trouble communicating but I always blamed my "non-standard" obdtool.com cable.
    Now the dealer is having the same problem so it's obviously not my cable.
    David said it could be an issue with older versions. My flash is two years old so I might as well update it. I've got nothing to loose and I could gain a couple ponies.
    Albert Einstein
    Woody Allen
    2003 A4 1.8T FWD 5M
    Puerto Rico
    I contacted my tuner. David called them and emailed the file. All this happened within the last hour or so.
    David doesn't know me nor is he making any money here.
    Did I say that his guy is amazing?
    Thanks a bunch David.
    Albert Einstein
    Woody Allen
    2003 A4 1.8T FWD 5M
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    nice...
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    bad ass ....
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Another one for the books. Man i see so many damn people that are more than satisfied with eurocode/revo than i do with any other company.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    West LA, CA
    i wish WalMart did german car tuning, chips would be like $50.
    Puerto Rico
    Would you put a sticker on your car that said "Tuned by WalMart"?
    Don't think so...
    Albert Einstein
    Woody Allen
    2003 A4 1.8T FWD 5M
    Veteran Member Four Rings SlvrB6Turbo's Avatar
    Jul 29 2004
    2002 A4 1.8TQM (Sold)
    Boston
    The same exact thing happened to me when I had a coil pack go last year around this time. My ECU needed to be replaced and my REVO was lost... I called REVO directly and they sent the new file to my local tuner (SWIFT MOTORSPORTS) where they re-flashed me for free. REVO has great customer service!
    |2002 A4 1.8T|Quattro|Manual|Light Silver Metallic|Ebony|Debadged|Sport|Premium|Convenience| Sunroof|Bose|Xenon|Cold|Podi Boost Gauge|Autovation Pedal Set|REVO Stage 1 Flash|REVO SPS-3|Forge 007 DV|SouthBend OFE SS Clutch|17" Mille Miglia Wheels|OEM Aero Wipers|OEM Rubber Mats|Dension IceLink+|99.9K Miles|SOLD|
    Registered Member Two Rings
    Sep 27 2005
    2004 A4 Avant and 1969 cadillac
    SG
    I would put sticker on car "POWERED BY WALMART"
    Jun 20 2004
    Dallas, TX
    When I upgraded to APR's big injector, I had the same issue where the dealer could not communicate with their VAG-1552. However, I had no problems with VAGCOM or an OBDII scanner. Let us know if the problem goes away with a reflash.
    Veteran Member Four Rings Nevaeh Speed's Avatar
    Jul 19 2004
    01' MK4 Golf 1.8t,08' 2.0t GTI
    Lancaster, Ca
    David and ecode are the shit!
    Please no more IM's. I'm no longer on this board. If you need anything I can be found at vwvortex.com under the Golf MK4 section under Nevaeh_Speed... Also on Dubberzine.com under Neaveh Speed... 1000rr.net under Nevaeh Speed.
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    Woot for David-hopefully I can use his services for some custom programming.
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
