Anyway I will post a lot of pictures throughout the whole process, well as much as I could have taken. The car was finished last night, so I haven't gotten around to get a ride in it.
The supercharger was ordered a few months back along with a STG 3 AMD clutch. The car made about 295WHP ON CPT's (heartbreaker) DYNO DYNAMICS before the supercharger install. The 295WHP was with a fresh carbon cleaning and a new lightweight flywheel and clutch along with a Full Catless Milltek exhaust 2.5 inch. So you guys know my old strong ASP STG 3 B5 S4 did 359WHP on this same machine.
The car has some miles, so they decided to put all new OEM injectors in while the Supercharger was getting installed. Also, 2 New OEM High Pressure Fuel pumps were installed.
The exhaust is a Full Milltek which I heard is shy of even 2.5inch. They said he would pick up about 20ish whp if he did a 2.75, but I know he loves the sound of the Milltek.
While the supercharger was getting installed Chicago Performance & Tuning changed out a few components on the kit...
Such as.
- eliminated plastic fittings with All new Aluminum fitting for the cooling circuit
- added hose protection (looks OEM)
- made Fan module bracket
- Custom made Heat Exchanger Brackets with Custom spacers.
- Swapped out the vacuum lines to OE vacuum lines which are just little more resistant to abrasion and it won't slip off.
OTHER THAN A FEW THINGS THATS CPT did above and beyond, the kits came out really nice! Fitment is great!
The Rs4 ended up Picking up an additional 125WHP, Which i would imagine would totally transform the car. It wasn't slow by any means at 295WHP. Now its at About 421WHP. It also picked up a low of TQ. On Any other Dyno it would be around 460whp and with another exhaust about 480whp ISH.
ONTO THE PICTURES! Check out the Video link on the bottom.
Here is the Carbon Cleaning going on
The Milltek Exhaust
OLD INJECTORS WITH OVER 100k MILES
NEW OEM INJECTORS INSTALLED
Here you can see the Lines with the added protection from the Supercharger to the Metal Y
Heat exchanger with new mounts and spacers
On the dyno
All done
DYNO PLOT OLD DYNO (non supercharged) VS NEW DYNO
BOOST (13PSI)
VIDEO
http://vid197.photobucket.com/albums...psayrs5qwb.mp4
