Results 1 to 9 of 9
    Aug 12 2015
    Minneapolis MN
    355mm Stoptech Brakes worth it?
    I track my vehicle multiple times per summer and was looking into updgrading my brakes. In the meantime I did the standrad upgraded to track pads and high temp brake fluid etc. I have dedicated 18" rims for the track so the best I can do is get the 355mm Stoptech BBK. While the stoptech rotors are larger than my current OEM rotors, will adding the BBK be worth it? I assume the calipers play into the overall performance to some degree as well. Will there be a noticibal improvement in braking etc?
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    BBKs typically have more pistons and larger rotors than stop set-ups. Both combined, add a greater level of stopping power and less brake fade over the course of your track day. If you're spending in excessive of $2-3K for it, only you can determine if the extra stopping power/less fade is worth the cost. Another option is looking to see if larger OEM calipers/rotors from another chassis will fit. I believe the Q5 will and it's a good alternative.
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Too bad you can't run 380's cause there's a good deal on StopTech's in the classifieds
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by db12 View Post
    Shedding weight off the wheels with the full floating two piece rotors and lightweight aluminum calipers is a huge advantage to you, especially on the track. The 355mm kit is still a significant upgrade over stock when paired with the 6 piston caliper. These BBK's are fantastic performers on the street and track. We get a lot of positive feedback from our customers with them.
    This is our best selling kit. Slotted with Red Calipers. if you do not see this for 2012+ fitment, type in 2011 they are the same fitment for all B8's.
    http://vag.excelerateperformance.com.../i-225706.aspx
    Any questions? PM me, call me at 203-483-6100 or e-mail me at [email protected]
    Thanks,
    Greg
    Aug 12 2015
    Minneapolis MN
    Quote Originally Posted by Excelerate Rep View Post
    Thanks,
    Greg
    What do most people do for the rear brakes when adding BBK? I assume and upgraded rotor of some sort with track pads. I had heard that maintaining the braking balance between the front and the rear can get tricky due to the fact we cant add BBK's to the rear of these vehicles.
    Aug 02 2015
    Corning NY
    Add Wave rotors and track/street pads.
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    Yes, if you are tracking the car, then it is totally worth it. But for anyone just driving on the street, even spiritedly, I would just stick with pads rotors lines and fluid. For me, especially having to run 19s in summer and 18s in winter, I don't believe my 18s will clear a BBK, maybe a 355 but not sure. So I am just upgrading everything else, since my car doesn't see track time.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Jul 18 2011
    Westchester, NY
    In all honesty, if you plan on tracking the car ALOT go for it. But, if you're doing it just for aesthetic purposes..really think about it before shelling out that much money.
    Just my 2 cents.
    Good luck!
    Current:
    2015 GTR FBO-600WHP
    2010 s4 prestige+: Every mod available
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Quote Originally Posted by b8audis4 View Post
    Running the 355mm kit will clear the stock 18's just fine. I added 3mm spacers to the front for a tad more clearance
