Well, I've had my 09 2.0 P+ for a year now, and she left me stranded for the first time last night. No warning signs. Started up after my lunch break and it was missing badly. Limped it to work, shut it off and tried to restart. Now it won't start... Great... So I go back to work and call a tow truck.
I pulled the codes when I got home- RPM too low, Multiple random misfire, misfire codes for all cylinders, and crank/cam correlation incorrect.
So based on that, I am assuming crank or cam sensor, which makes sense with the symptoms. I took a multimeter to both sensor and I had difficulty getting a reading from the cam sensor, crank seems ok, but I'm not sure what the specs are on it. CarQuest had a cam sensor in stock for $15, so I started there... No luck. Currently waiting on crank sensor to get here in a couple hours.
Any other suggestions on what it could be, other than that, just in case? Based on the codes and symptoms, the crank sensor seems to fit the bill, but I wasn't sure if there was something I might be missing here.
