Results 1 to 18 of 18
    Established Member Two Rings SilverRings's Avatar
    Aug 20 2015
    Louisville, KY
    Boost Gauge Options
    Well, I tried the search and came back with very little info comparing options. So far, I am considering the P3Cars (with OBD connection) or a AWE with boost tap.
    What are your all opinions of the P3cars gauge hooked to the OBD port? When you are driving, I know the boost reading will not be as responsive as a boost tap/gauge combo. But, how bad is the polling speed? If you go through the gears, will you be able to see max boost, or is it too slow for that? What are the negatives of the P3Cars gauge?
    What are you opinions on digital readouts vs regular needle gauges for the left vent? I know that's a loaded question, given everyone's preferences. I know that you can do more with the P3cars gauge, for sure.
    Is there anything else that has come up with gauges on the forums that I need to know about?
    2011 Audi S4 // P+ // Sport Diff // DSG
    EPL Stage 2 and TCU | AWE Touring Exhaust | 19x10 et42 Forgestar F14s | Ventus V12 255/35/19 | KW Street Comfort Coilovers | EuroCode Rear Sway Bar | EuroCode Trans/Diff Mount Inserts | EuroCode Alu Kreuz Driveline Stabilizer | CR15 Strut Tower Brace | StopTech SS Lines and Fluid | Akebono Euro Pads | Centric High Carbon Discs
    Aug 23 2014
    Philadelphia, PA
    Another option would just get P3's Boost gauge which is not OBDII and runs off boost tap (not included). Still on sale through this month and honestly what we prefer as we like the clean install look P3 gauges provide
    https://www.moddedeuros.com/products/p3-cars-boost-gauges-red-white-09-15-a4-s4-10-15-a5-s5
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    I have a P3, and I like it aesthetically. Its very clean, but can be incredibly distracting as the boost values constantly change. I didn't think too much about it when I got it, because I liked more how it looked than the other boost gauge options. I also wish there was a away to turn off the numbers, and just let the bar readout do its thing for long night drives, but at least you can dim it when needed.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    See next post.
    Sep 24 2014
    Central NJ
    The P3 OBD digital gauge update rate is plenty fast/responsive enough, that is not a limitation. An analog gauge is certainly has better readability for these types of measurements, but you lose all the other P3 parameter readout functions, which are nice to have.
    In reality, I have only really looked at the boost gauge to check the maximum, so the digital readout is fine for that. And the analog bargraph gives you a proportional view. Do you really care if you are at 6.5 PSI of boost, versus 6.7 PSI??
    Another discussion point on these gauges that they read the boost pressure from the OBD datastream : Some people claim this is not as accurate as a "real" boost gauge hooked-up to an intake manifold tap. I don't agree, as there are actually 2 boost parameters on the OBD datastream : "Actual" and "Requested". Actual, as it implies, is based on the readings from the boost sensor. Requested is the amount of boost that the ECU is "requesting".
    If the P3 OBD gauge is displaying the "Actual", then the accuracy will be as good as the accuracy of the OEM solid-state boost sensor used, which is probably more accurate than what is supplied with aftermarket electronic gauges, or the accuracy of aftermarket mechanical boost gauges.
    If the P3 OBD gauge is displaying the "requested" boost data, that is perhaps a little less accurate than Actual, but if it deviates enough from the actual boost (as measured by the OEM boost sensor on the engine), you will get a check engine light / DTC (and go into a "limp-home protection mode"), as the ECU will flag this as a problem if the two values don't match closely.
    I have asked P3 Cars if their gauge displays Actual or Requested manifold pressure datastream values in VW-Audi gauge versions, but I have never gotten an answer.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    You can change how many decimals the boost reads if you don't like it changing constantly.
    .1, .5, and whole #s are all options. Not sure about the bar graph only without numbers, but play around with it. Also, get the analog boost tap and it'll read actual boost and give you the best of everything, unless you are partial to mechanical gauges/needle reading.
    http://www.p3cars.com/vag-install
    Oct 02 2006
    Wadsworth,OH
    Below is our vent pod option.
    Jason
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    I went with AWE first and then swapped to P3. P3 is a cleaner install and I did the analog boost tap for it.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    I think I would find the P3's constant flashing lights too annoying as well, especially at night. Can't beat a tradition gauge for being easy to read without being too distracting.
    Aug 23 2014
    Philadelphia, PA
    Quote Originally Posted by onlyaudis View Post
    I daily drive a S3 with the gauge for over 30,000 miles now (we actually testedthe s3 gauge for P3 guys before it was out) and it never once bothered me while driving. Honestly is not distracting. Just like the main cluster
    P3 looks like it came with the car whereas feel some other designs are out of place
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Quote Originally Posted by ModdedEuros View Post
    I'd say it's alright for others to disagree with you, no? When the numbers are changing frequently it definitely is a distraction to me.
    Aug 28 2013
    Winnipeg
    P3 gauge ftw definately! You can dimm the gauge at night no problem and possibillity to add analog boost tap
    Best feature to me, it looks absolute oem
    Also so many other feature you really cant beat that!
    Sent from my SM-G925W8 using Tapatalk
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    P3 or nothing! A luxury sedan with a boost gauge looks sooo tacky! The P3 looks very nice and OEM.
    Aug 28 2014
    Check out the Podi boost guage with their OEM looking steering column pod mount. You can set boost warnings and change color of guage with included remote.
    Sent from my XT1585 using Tapatalk
    2014 S4 - Moonlight Blue
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    Personally I prefer analog gauges, I'm very happy with the AWE gauge. Nice colour match and is a clean looking install. P3 is nice because it has multiple setting parameters, but I find it tacky looking when it's on. But I'll admit it looks better with the white display vs the red.
    Sent from my Note 5
    Bryan
    Mar 13 2013
    Chicago Western burbs, Il
    The P3 offers a lot of info concerning how your engine is running, EGT, ignition timing and boost to name a few, you can config to turn display off completely if you're on a long night drive but the dimmer isn't that bad. The only bad, it doesn't give you IAT's only outside air temp at your air filter which is completely useless for the supercharged 3.0 engine. Many have asked P3Cars to change, including myself but all we get are crickets, not sure why.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    P3 all the way. Thread End !
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Mar 13 2013
    P3cars replied to my question on Facebook concerning after IC IAT's and they are currently working on expanding the list of data points they can display on the VIDI. Good news for P3 customers. No timetable but good to know somethings in the works.
